![]() Join Date: Oct 2010
Front coil spring stuck!
(73 c10)
well.. i started tearing into my front end this morning so i could clean it up and replace all bushings and ball joints, and i kinda expected a little tension on the coil spring when i dropped the lower arm, and the spring didnt move at all. i took the rest apart and it seems that the spring has 2 coils wedged into the upper spring socket, as if someone jumped it or hit somethin really hard. any ideas on getting this out safely without damaging other parts or myself?? btw, not planning on keeping this spring, so i was thinking plasma cutter unless you guys have any ideas to just get it out and i could possibly save the spring. thanks guys. |
Re: Front coil spring stuck!
here are a couple pictures of what im workin with.. i left the lower arm on so i might be able to compress the spring and try that route.. but i think im gonna have to end up cutting it..
yeller
Raise the LCA enough to contain the spring should it try to shoot out, then kick the spring a few times with your foot or hit it with a 5 pound sledge...it'll pop loose. Same thing happened to my 77 on one side. When mine came loose, it just fell down, there wasn't much, if any tension on it at all.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 11-01-2010 at 10:05 PM. |
ill give it a try, but i tried using my prybar wedged between the spring and the perch and it wouldnt move at all, do you think the lower arm would relieve that much tension?
Robert Olson Transport
![]() Join Date: Oct 2002
YES... i used a large prybar to pop mine out not much tension when i did it
could always sawsall it too
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! Last edited by old Rusty C10; 11-01-2010 at 09:53 PM. |
well.. its out.. it took the gentle persuasion of a ratcheting tie down(now broken), two rather large pry bars and a hammer.. and it was locked in there tight.. you guys must have had it made with yours.. this one was tough. but thanks for the input you guys, im just glad i was able to save the coil.
btw... anyone need any 1/2 ton front coils?? |
