Old 11-02-2010, 02:28 PM   #1
pcwillsie
dash pad question
I was wondering if a dash pad off of a 73 will fit in an 87 cab. are there any modifications needed?
pcwillsie is offline   Reply With Quote
Old 11-02-2010, 03:04 PM   #2
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: dash pad question
the dash is totally different. It will not work.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 11-02-2010, 04:22 PM   #3
sixshooter798
Desert Rat
sixshooter798's Avatar
I put a dash pad out of a 78 in my friend's 86 Blazer. The instrument bezels are different, so we had to get one from the local junkyard. The Bezel we got had holes for the windshield wiper switch as well as the headlight switch. The Blazer had the w/w on the column. Also, the headlight switch was in the wrong spot. We drilled a new hole for the headlight switch and moved it down. We took some black plastic and filled the hole where the windshield wiper switch would have been on the bezel, and installed a toggle switch for the off-road lights. Lastly, the lower bezel, the part that goes beneath the steering wheel, was also different. Again we were able to get this part from the local junkyard.
In short: yes you can do it, but its a bit of a pain.
sixshooter798 is offline   Reply With Quote
