11-03-2010, 01:14 PM | #1 |
82 Chevrolet c10 build sheet!
Where exactly would the build sheet be located on an 82?
Posted via Mobile Device |
11-03-2010, 01:30 PM | #2 |
Re: 82 Chevrolet c10 build sheet!
As far as what options the truck had? It would be on the inside of the glove box door.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
11-03-2010, 01:39 PM | #3 |
There supposely is one more that tells what the original color was, what options, date manufactured and what location. Read a few forums and they said it will be around the bed underneath.
11-03-2010, 01:42 PM | #4 |
I think they're usually under the seat in the springs or under the carpet. somewhere like that.
This is the one for my 78. |
11-03-2010, 01:43 PM | #5 |
Only one I have ever seen was in the glove box. It will tell you colors, options, ect...
11-03-2010, 01:48 PM | #6 |
Thanks for the help! I knew about the glove box one but thanks for the help. I will check under the seat and in the springs
11-03-2010, 01:52 PM | #7 |
it's just a plain ol piece of paper. doesn't stick to anything and it just got stuck somewhere in the truck going down the assembly line somewhere.
The one in the glovebox is the RPO sticker. |
11-03-2010, 02:12 PM | #8 |
Real Projects never die
if they arent in the glove box ive seen some trucks with them on the drivers side inner fender under the hood, same plastic and everything as the glovebox location, but this was mainly on 73-74s for some reason. I cant remember if ive seen them on anything later than that on the inner fender.
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
11-03-2010, 02:18 PM | #9 |
There is a difference between the SPID label and the build sheet (both of which have been attached in this thread).
The SPID label is the plastic covered sticker, located on the front fender inner wheelhouse or in the glovebox. It is an official document and was required to be placed on the vehicle before it left the assembly plant (for service use). The build sheet is what 78 Chevyrado posted; it is a document for use in the assembly plant to help the line operators determine what parts to put on the truck. There was no requirement for those to be placed in the vehicle, and there is no usage for that document once the truck leaves the plant (other than for us hobbyist/enthusiasts). However sometimes it was easier for the operator to just leave it laying in place rather than throwing it away. Usual places can be in the seat cushion or base, behind the door trim panels, under the IP top pad, stuffed in the A pillar or under the carpet - or - none of the above. They will often be ripped, torn, stained or have a bolt driven through them. If you find one of these you are very, very lucky. Thanks for posting that , 78 Chevyrado, it's a beautiful thang - K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 11-03-2010 at 02:27 PM. |
11-03-2010, 02:26 PM | #10 | |
Keith, dont mean to challenge you, but we own quite a few 73-80s, and most of mine are in the glovebox, excluding my dads 73 and a few others. By alot, i mean 20-25. Are you sure the changeover date wasnt earlier?
11-03-2010, 02:26 PM | #11 |
I'm not sure where mine came from, Granddad doesn't remember where he got it.... it was in a file he made for the truck that he gave me when i got the truck from him.
He keeps all that stuff... A month ago or so, we found his original bill of sale for a 1949 Ford Car He bought new, only option was a heater. Last edited by 78 Chevyrado; 11-03-2010 at 02:30 PM. |
11-03-2010, 02:31 PM | #12 | |
Yep - not sure on that one, and had already edited my original post (because I couldn't remember - and because I didn't want it to detract from my info). Changeover could have been prior (and was likely) prior to 80/81. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 11-03-2010 at 02:33 PM. |
11-03-2010, 08:47 PM | #13 |
1973 GMC 2500 Grande Sierra with 70,000 orig kms ( Current project ) 1971 Karmann Ghia 1967 Ford Thunderbird 2 x 1973 Chevy 3+3 Dualies |
11-03-2010, 10:12 PM | #14 |
My old blue 84 had it on the inner fender. Years ago my dad had an 84 that had it in the glovebox. Had a 79 that had it in the glovebox IIRC. My 89 has in the glovebox too. I've seen the same years of truck have them in both spots.....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
11-04-2010, 12:01 PM | #15 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
11-04-2010, 04:58 PM | #16 |
have an 84 K5 with the SPID labelon the inner fender
11-04-2010, 08:16 PM | #17 |
I think the location of the SPID varied between plants;I have seen them on the fenderwell and in the glovebox up to 76-78...after that they all seemed to be in the glovebox.
The build sheets seem to be under the seat in a lot of the USA built trucks I have seen...very few in the Canadian trucks. |
