11-04-2010, 08:27 AM | #1 |
BLACK SATIN
WTB power steering box for 250 non integrated
I have the pump, brackets & alternator from a 78 Nova & I need the power steering box. I am putting it on my 67 C20. Thanks in advance.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new 67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering 85 C10 Silverado- 305ci Last edited by ges55; 11-04-2010 at 08:33 AM. |
11-04-2010, 02:21 PM | #2 |
BLACK SATIN
Re: WTB power steering box for 250 non integrated
ttt
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new 67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering 85 C10 Silverado- 305ci |
11-04-2010, 02:31 PM | #3 |
"Trucks with Class"
Remember, all PS "boxes" are the same...nothing special about 6 cyl. '73-78 are quick ratio, which is nicer with the stock sized steering wheel.
11-04-2010, 03:49 PM | #4 |
BLACK SATIN
Thanks, I didn't know that.
11-04-2010, 04:07 PM | #5 |
Will 73 and up fit in our trucks without modifications?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
11-04-2010, 04:20 PM | #6 |
I got one in my 71 c10 Im parting out.. check out the thread and let me know. lets make a deal!
http://67-72chevytrucks.com/vboard/s...d.php?t=426604
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 http://i195.photobucket.com/albums/z...en58/001-2.jpg |
11-04-2010, 04:28 PM | #7 |
"Trucks with Class"
Yes, but always check everything twice+, when you are making changes. Be sure the pitman arm to tie rod is correct/the same.
11-04-2010, 04:46 PM | #8 | |
Project Junkie! Fishing Poor!!
If you want to mount an integral steering gear to your 67 chassis you need to heat up the chassis where the steering gear mounts and dimple it to make room for the integral gear. Otherwise the ram assist power steering set up is what you will be looking to get. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
11-04-2010, 06:55 PM | #9 |
"Trucks with Class"
I recommend you stay away from that old ram system. There are more things to go wrong and it uses the manual box with too many turns lock-to-lock. You have trouble getting parts for it. Check to make sure, some late 67 frames had the indent for PS box.
11-04-2010, 07:08 PM | #10 |
pre 76 boxes have a small spline on the steering rag joint 77 up has a larger spline there, it will bolt up to 67-72 ,but you need the 77-up joint to do so..
Also you have the lines..early are flared...later ones have o-rings..been there,done that several times.. |
11-04-2010, 09:51 PM | #11 |
"Trucks with Class"
Just stay away from the late 70s boxes that use the o-rings. All of the earlier inverted flare type take our correct PS lines. If you are not comfortable with all of this early vs late boxes, just get 68-72, they are easier fit in our trucks.
11-05-2010, 12:26 PM | #12 |
BLACK SATIN
Thanks for all the good info.
