11-05-2010, 01:11 AM | #1 |
Width of the rear...!?! WMS-WMS
Hello everyone. I'm looking for the wheel mounting surface to wheel mounting surface for the rear axle in a 1978 2wd c10 12 bolt. I've search the forum with no luck, and found everything but on the web. Looking to swap out my 3.07 open diff to at least a posi unit, higher gear a plus. Need the width so I can see what donor vehicles to search for. I could go pull the tires off my truck, hoping somebody has the info though....Thanks.
11-05-2010, 11:43 AM | #2 |
Always a work in progress
Re: Width of the rear...!?! WMS-WMS
It is right around 65 inches if I am not mistaken. I have a ford 9" that is 65" wms to wms and I shouldn't have any problems putting in under the truck. You can find the 9" all day long bc they were used in so many different vehicles for a long time. I got mine for $50 drum to drum. To keep costs down just have the axles redrilled along with the drums. I am going to see if the drums are will swap between the 10 bolt and 9" to try and save even more $$$.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
11-05-2010, 01:40 PM | #3 |
Yeah I have a 12 bolt in my 78, not sure if its the same wms-wms as the 10 bolt...anyone?
11-05-2010, 11:45 PM | #4 |
BMW & ASE Master Certified
I'ive got a 12 bolt in the garage. I am going to the garage tomarrow afternoon, I can get a tape measurement for you.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
11-06-2010, 12:46 AM | #5 |
That would be great, I would like to find something Sunday at the swap meet, there's no way Ill have time to get to my truck and pull the wheels to get a measurement, Thanks.
11-06-2010, 10:03 PM | #6 |
Going to swap meet in the a.m., anyone have a hard measurement? SEND it PLEASE even if its late tommoro. Thanks
11-06-2010, 10:55 PM | #7 |
67-72 parts collector,…
64-3/8".
Just measured the one I took out of a 87 1/2 ton 2wd Suburban.
11-07-2010, 10:45 AM | #8 |
Ditto on that measurement. I'm putting a 3.42 posi from an 87 suburban today. 11.25" drums, 2.75" shoes, all match the 3.08 coming out of a 76.
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262 http://beerbreadbike.wordpress.com/ |
