Old 11-12-2010, 02:41 PM   #1
1968CHEVYC10
1968CHEVYC10's Avatar
82 6.2 diesel and mechanical clutch linkage
I'm looking at a 82 6.2 diesel engine to swap in place of my 350. I currently have a 3 spd manual trans with mechanical clutch linkage, and part of the linkage is attached to the block of the 350, I've done a little research and the pre '85 square body's had the clutch linkage attached to the bellhousing, not the block, so has anybody dealt with this before? is there some kinda adapter out there? or could I drill and tap some holes in the 6.2 to mount the linkage? Swapping the trans also would fix it and I would like to do that at some point but it's really not in the budget. Thanks Yall!
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 11-13-2010, 02:11 AM   #2
1968CHEVYC10
Re: 82 6.2 diesel and mechanical clutch linkage
Any help?
Old 11-13-2010, 02:33 AM   #3
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Not familiar with the 3 speed manuals in the square bodies. (My 6.2 is in front of a TH350). I'd stay away from drilling into the block though. Maybe build your own adapter out of some scrap sheet metal?
lindstromjd is offline   Reply With Quote
Old 11-13-2010, 02:39 PM   #4
raycow
How about making a bracket that attaches to the bellhousing bolts? I would be scared of putting holes into the 6.2 block unless there are existing bosses for them.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
