Old 11-16-2010, 09:38 AM   #1
monza1979
monza1979's Avatar
wiring annoyances
so on my 78 4x4, have a choke light that flashes, only started after i replaced the carb with an edelbrock 1406. checked all of the grounds in the surrounding area and all seemed just fine. question with that is what hotwire could be shorting to cause this light to flash/turn on? not sure at all what this light is supposed to actually indicate. and second off, where is the "brights indicator" supposed to be? as long as i've had the truck i have not had the indicator. not sure if thats just a bulb burnt out or something deeper.
I had the right to remain silent, but i didn't have the ability!
78 chevy swb 4x4 sm465 np205 350 4" lift, ORD flip kit, ORD Ext. brake lines
79 Chevy Monza:current plans, dz 302, 4 speed
69 Pontiac Firebird: 74 s.d. 455 build up, m22 rock crusher
monza1979 is offline   Reply With Quote
Old 11-16-2010, 10:52 AM   #2
HOGDADDY
HOGDADDY's Avatar
Re: wiring annoyances
Did the carb you replaced (quadrajet?) have electric choke? If so maybe the hot wire for it is making contact.
Are you not using electric choke on Eddy carb?
HOGDADDY is offline   Reply With Quote
Old 11-16-2010, 11:00 AM   #3
monza1979
monza1979's Avatar
yea, the eddy replaced the quadratoilet. i am using the electric choke. i chased that wire back and there is no burnt or chaffed wire on it. i even replaced the wire just to make sure. still flashes. very spirattically, no rhythm to it at all.
Old 11-16-2010, 02:17 PM   #4
knightowl73
TUKE-NoBullChit Customs owner
knightowl73's Avatar
maybe the pins on the connector for the guages are coming loose. i think that is the problem on one of my trucks. my guages start all acting up and high beam indicator and both turn signal indicators stay lit up. sometimes i can grab the harness under the dash at the guages and jiggle it until it starts acting right, but just not lately. one thing to check tho.
OWNER @ NBC Customs...No Bull Chit....'92 GMC C2500 ECSB 350/TH400, '57 FORD SKYLINER (My dad's for now, but its really mine-you'll NEVER see a cooler car at 7 years old lol), '42 ford rat rod shop truck (new project), 91 CHRYSLER VOYER MINIVAN (shop van for now)
http://www.facebook.com/#!/nbc.customs
knightowl73 is offline   Reply With Quote
