Old 11-17-2010, 11:16 AM   #1
RocketKing
RocketKing's Avatar
static drops and oil pans
Any of you guys running around a 4" drop with the stock truck oil pan.
My pan is sticking about 2" below the front crossmember and with just a 2" drop or so I don't think it would not be a problem but with the 4" things might get tricky.
I did a search but all I could find was bagged trucks that were even lower than mine.
Just wanted some info before I spend some cash on a f-body pan.
Thanks!
Rex
RocketKing is offline   Reply With Quote
Old 11-17-2010, 06:58 PM   #2
LEEVON
LEEVON's Avatar
Re: static drops and oil pans
What truck? I had a to use an f-body pan on my bagged '50. I wouldn't want the oil pan any lower than the front crossmember no matter what. There are a couple other solutions besides f-body but it definitely is the most shallow of the stock wet-sump pans. The GMPP conversion pan for one, Cadillac CTS-V, GTO, Vette...
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 11-17-2010, 08:12 PM   #3
RocketKing
RocketKing's Avatar
LQ4 engine, that deeep pan. I may have been mistaken but the GMPP conversion was only about an 1" shorter than the stock pan. But I will check into the others and see if one will work, thanks for the heads up.
Rex
