Old 11-17-2010, 11:39 AM   #1
gofast321
Exhaust Manifold AIR Plugs - 85 Burb 454
I have an 85 Suburban with a 454 that I recently purchased. The AIR ports in the exhaust manifolds have been pluged with fittings that have a pipe thread to them and a flat top that allows me to tighten them down like a large screw. Recently one of those plugs has backed out and was lost. I have replaced it with an NPT fitting. The problem with the fitting is that it will not allow me to tighten it down because it has a continuous thread and consequently it keeps backing out and I have to constantly replace it.
Does anyone have any suggestions on what I can do to either keep the NPT seated or where I could find a plug similar to my other ones with the flat "screw type" top?
Thanks for the help!
gofast321 is offline   Reply With Quote
Old 11-18-2010, 06:44 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Exhaust Manifold AIR Plugs - 85 Burb 454
try plumbing store
then tac weld em if yer never gona usem again
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 11-18-2010, 12:44 PM   #3
gofast321
Thanks for the suggestion, but walking around the plumbing department of Home Depot last night I came up with a solution. I ended up buying a 1" piece of 3/8" iron pipe that isn't threaded all the way through. Then I also bought an iron cap for the pipe. It screwed right into the open port and since it wasn't threaded all the way through I was able to tighten it down. Plus the 1" piece sticks out just enough to give me a good grip to tighten it by hand.
Old 11-19-2010, 01:13 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
good idea
John
