Old 11-19-2010, 01:50 PM   #1
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Blazer/burban rear bumper
i know i need one of the truck brackets but what one is it inner or outer?
i got the outer ones from an 84 85 gmc like mine but i think i got the wrong ones oh well the 5 bucks i payed for a near mint dark gray dash pad and 6.2 Diesel hood ornimate made up for it
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 11-19-2010, 03:33 PM   #2
bharrison1
bharrison1's Avatar
Re: Blazer/burban rear bumper
you will need the inner brackets
bharrison1 is offline   Reply With Quote
Old 11-19-2010, 03:48 PM   #3
3r!c84
Badass
3r!c84's Avatar
You don't need the inner. They are like 50$ each new. Just bolt it in with the outers and put the inner bolts in the bumper for show.
I did this . It is plenty strong
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-19-2010, 04:32 PM   #4
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
ok? maby i have them on backwards because they dont seem to line up....
Old 11-19-2010, 04:49 PM   #5
3r!c84
Badass
3r!c84's Avatar
yea maby you got them wrong.
heres mine with just the outers.
(its tucked in about a 1.5inchs)
-00 Saturn 5spd
1/4:13:90
Old 11-19-2010, 05:01 PM   #6
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
see in your second pic your hand...where you finger is. that is roughly where my bracket bolt holes are. they wont line up with the outer bumper holes at all....... seems way off :S?
Old 11-19-2010, 05:02 PM   #7
3r!c84
Badass
3r!c84's Avatar
it should be that in. i drilled holes 1.5 inchs back from the origanl ones
-00 Saturn 5spd
1/4:13:90
Old 11-19-2010, 05:04 PM   #8
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
i'm going to get a fresh pair of eyes to look at it lol i might be going
truck looks Great BTW
Old 11-19-2010, 05:19 PM   #9
boatpuller
boatpuller's Avatar
you just need the outers.i ran a burb bumper for a few year's.i switched to a sport and only have outers.it's fine for look's.but,i wouldn't stand on it.the last pic is older showing the burb bumper...my 79 is just for look's.all it haul's is "a$$".
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 11-19-2010, 05:28 PM   #10
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
see my bracket sticks way over by the bed side almost.grrr lol i don't understand what im doing wrong :S Jimmy bumper and 84 truck outters hmmmm
Old 11-19-2010, 05:34 PM   #11
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
I have to have the wrong bracket or something mine looks WAY longer than yours
Old 11-19-2010, 05:38 PM   #12
3r!c84
Badass
3r!c84's Avatar
Go back and get the brackets. Or find them off a bother truck
-00 Saturn 5spd
1/4:13:90
Old 11-19-2010, 05:43 PM   #13
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
off the jimmy/burban or a 81-87 truck?
Old 11-19-2010, 05:48 PM   #14
3r!c84
Badass
3r!c84's Avatar
What ever u find that has the same bumper as yours. Don't matter truck or burb or Jimmy
-00 Saturn 5spd
1/4:13:90
Old 11-19-2010, 05:49 PM   #15
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
ohhhhh it had to have that style bumper... Great.... lol that's like Gold Around here
Old 11-19-2010, 06:01 PM   #16
3r!c84
Badass
3r!c84's Avatar
Lol lmc has them . The outers are like 20$ each. The inners are like 50$ !!!! Each
-00 Saturn 5spd
1/4:13:90
Old 11-20-2010, 10:39 PM   #17
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
lol found a set for free. just my luck along with a 89 jimmy steering wheel and front air dam oh and Truck band for i can mod the jimmy band.... Thanks DAVE! your the man
Old 11-20-2010, 11:14 PM   #18
harnalien
TruckincrazY
harnalien's Avatar
Hmm, only the outers? I may have to take a trip to the junkyard to see what I can find!
harnalien is offline   Reply With Quote
Old 11-20-2010, 11:17 PM   #19
78 Chevyrado
I love the way the tucked rear bumper looks, but if you get hit in the back by even a bicycle, it's gonna drive the bumper into the rear end of the bedsides, especially if you use only outer or inner brackets alone.
Basically whatever happens, if anything taps that bumper, its time for paint.
78 Chevyrado is offline   Reply With Quote
Old 11-20-2010, 11:24 PM   #20
3r!c84
Badass
3r!c84's Avatar
lol if my truck was going to get hit. (by a truck) the tail gate would be the first thing theyd hit.
-00 Saturn 5spd
1/4:13:90
Old 11-21-2010, 01:40 AM   #21
flamingbig10
6.0 powered square
flamingbig10's Avatar
I'm using the inner burb brackets bolted to flat stock
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 11-21-2010, 03:35 AM   #22
jitteryguy
GoatLube Experss
jitteryguy's Avatar
I only have the outer brackets on mine as well, most any thing that hits it from rear will probably be higher than my bumper any way so ,,,,,,,,,,,
no differance than have'n a roll pan like I have on my '88 S10 .
also all three of my trucks need paint any way so hopefully they decent insurance .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 11-21-2010, 06:47 PM   #23
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
other than a good clean up lol and some paint the truck i like it's look
Old 11-24-2010, 12:54 AM   #24
hitcher
hitcher's Avatar
im assuming its the same for my 88 1 ton ? i was told that brackets from a blazer would fit but a suburban wont , is that right ? im needing all the brackets to fit a bumper like 3r!c84's truck
hitcher is offline   Reply With Quote
Old 11-24-2010, 01:20 AM   #25
3r!c84
Badass
3r!c84's Avatar
Blazer and burb ones both fit. Only the outer brackets from them fit. You will need to find a truck with a sport bumper to get the inners. ( good luck with that) or order new inners. Or like me only run the outer brackets.
-00 Saturn 5spd
1/4:13:90
