Old 11-21-2010, 06:50 PM   #1
shenk10
shenk10's Avatar
How to prove ls2
How do you double check an engine is an ls2? Looking at an ls2 that a guy has and just want to double check that it actually is an ls2. Thanks
Jordan
1972 Chevy K5 Blazer, 6" Lift, 35x13.5R15, 6.0/6L80E/NP205
1982 Chevy C10 SWB, 2006 LS2/4l70e
In progress....
http://67-72chevytrucks.com/vboard/s...d.php?t=439860
shenk10 is offline   Reply With Quote
Old 11-21-2010, 08:47 PM   #2
85burb
85burb's Avatar
Re: How to prove ls2
The block should be aluminam and stamped 6.0 on the cylinders on the front and rear of block. http://www.ls1tech.com/forums/genera...g-numbers.html This may also help.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 11-22-2010, 03:00 PM   #3
shenk10
shenk10's Avatar
okay thanks, i might just take a magnet with me, I'm sure I could also check the serial number on it also
Jordan
In progress....
Old 11-22-2010, 03:27 PM   #4
MONTEZ
To see if it sticks to the block? You'll know if it's iron or aluminum just by looking at it. The iron ones get surface rust on them pretty fast. Even still, the block itself will look different from the cast iron to the cast aluminim. The iron will be a lot darker than the aluminum will be and will more than likely be painted wher as an aluminum one won't be, unless the PO painted it.
Smoke Tires, not Drugs
MONTEZ is offline   Reply With Quote
