11-21-2010, 07:28 PM | #1 |
Staright Plug Heads
I just bought a 355 engine and it has Straight spark plugs out of the heads and I want to know what type of headers can i use to have clearance for the plug and wires? And a good place to buy them at?
Here is a picture of the motor.
87 2wd GMC Sierra Classic. 86 4wd GMC Sierra Classic. 95 2wd GMC Sierra. 96 2wd Chevrolet S-10. |
11-21-2010, 07:34 PM | #3 |
Re: Staright Plug Heads
I agree toss the flex fan before it puts a blade through your hood. Pretty much any standard headers that are for your truck will work fine. Straight plug is the normal thing. If you had angled plugs its a bit more difficult.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
11-21-2010, 08:07 PM | #4 |
Ya i am going to go with electric fans instead of that.
But any headers will work? and were is the best deals to get a pair?
11-21-2010, 08:13 PM | #5 |
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] Last edited by GMC Guy; 11-21-2010 at 08:16 PM. |
11-21-2010, 08:22 PM | #6 |
Alright. i will see what i can get.
11-21-2010, 08:55 PM | #7 | |
C35 Crew Dually
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
11-21-2010, 10:18 PM | #8 |
Any small block headers designed for correct year C10's..etc should fit fine.
The Ebay headers that are pictured do not appear to have mandrel bent tubes, it appears you spent some money on an engine that you want to perform, so I would use a different set, if it were me. Stainless would be nice, but unless youre just trying to dress up a low performance motor, Id buy a plain steel painted set from a reputable company first. |
11-21-2010, 11:22 PM | #9 |
Just wondering....what about if you want to put A/C on it? The A/C compressor bolts onto the front of the left header if I'm not mistaken...can you just modify the bracket or something?
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
11-22-2010, 12:12 AM | #10 | |
11-22-2010, 12:14 AM | #11 |
I am not going to use the A/C any more. I dont even have the belt on it right now. The compressor does not work to well and the system has no coolant in it.
11-22-2010, 01:02 AM | #12 |
At the body shop.
Dougs d-310c 3/8 flange 1 5/8 tube 3'' collector spendy but fit well and do not hang below rail. got them on my 73
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 11-22-2010 at 01:02 AM. |
11-22-2010, 01:09 AM | #13 |
Just came back and noticed your valve covers....those are the ones I have been looking at getting (Edelbrock Elites right?) except I gotta get the stock height instead of tall because of the A/C bracket no doubt
11-22-2010, 01:24 AM | #14 |
God is good!
No, not just any header set will work, even the ones that are "supposed" to fit your specific application. I used to have Hedman (if I recall the brand) headers on my K5 that didn't cause any major clearance issues, changing plugs was easy, but when I put some Hookers on my '65 Impala I had to put a dent in one of the tubes to clear a plug, get a smaller oil filter, and use a box-end wrench to install/remove one of the plugs. And they were specific to my application. There are actually spark plug sockets made to change plugs on engines with headers.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
