Old 11-21-2010, 09:34 PM   #1
68chevyfuelie
68chevyfuelie's Avatar
WTB 4.56 gears
Looking to purchase, OEM only, 4.56 ring and pinions for Dana 44, Dana 60, and GM 12 bolt. No surface rust, no chips, must be fine spline pinion. Willing to purchase Dana 60 4 series 30 or 35 spline carriers with gears, if you won't split up. MUST be Dana/Spicer/OEM, no aftermarket junk, please. Would also consider 4.10 for Dana 44 LP and GM 12 bolt. Thanks!
68chevyfuelie is offline   Reply With Quote
Old 11-24-2010, 10:22 PM   #2
68chevyfuelie
Re: WTB 4.56 gears
bumpski
Old 11-25-2010, 10:10 AM   #3
70BLAZERX2
Re: WTB 4.56 gears
I have a dana 60 posi carrier with 4.10 gears If that will work for you.
I would have to weigh it and see how much shipping would be. I would need your postal code.
I will get pics of it too. $100 plus shipping.
70BLAZERX2 is offline   Reply With Quote
Old 11-25-2010, 04:36 PM   #4
68chevyfuelie
Re: WTB 4.56 gears
Powr-lok or trac-loc? 30 or 35 spline side gear? Zip is N2H 5H1. Interested if it's a Powr-lok. Thanks.
Old 11-25-2010, 08:38 PM   #5
70BLAZERX2
Re: WTB 4.56 gears
This is what i have here..These are out of a 1980 F250 Dana60 rear end.Has the clutch type posi and is a 35 spline axle gear. 4.10 ratio gears..but carrier is for 4.10 and up.
Old 11-25-2010, 11:13 PM   #6
68chevyfuelie
Re: WTB 4.56 gears
So it's a 4 series Trac-loc, for 4.56, 4.88, 5.13, etc gears? Or it's a 3 series for 4.10, 3.73 and 3.54?
Does it have aftermarket gears, or how do you know its for 4.10 and up?
30 spline, or 35 spline side gears?
Old 11-26-2010, 10:44 AM   #7
70BLAZERX2
Re: WTB 4.56 gears
The dana60 are different than other rear carriers..this is for 4.10 and down..like 3.73..3.42..ect..
4.56 wont work on this carrier.
Old 11-27-2010, 09:34 AM   #8
68chevyfuelie
Re: WTB 4.56 gears
[QUOTE=70BLAZERX2;4314037]This is what i have here..These are out of a 1980 F250 Dana60 rear end.Has the clutch type posi and is a 35 spline axle gear. 4.10 ratio gears..but carrier is for 4.10 and up.
/QUOTE]
Can you get me the ring gear and pinion number? I would go $150 shipped, but I want to make sure its not Dana 61 parts. You're sure 35 spline side gears, right? Thanks.
Bump for anyone with 4.56.
Old 12-02-2010, 03:03 PM   #9
68chevyfuelie
Re: WTB 4.56 gears
bumpski
Old 12-12-2010, 06:40 PM   #10
68chevyfuelie
Re: WTB 4.56 gears
bumpity
