Old 11-23-2010, 11:47 PM   #1
f.monroe
f.monroe's Avatar
73-80 12 Bolt question
Are the 12 bolts from C10's and K10' the same width. I am looking for a 12 bolt with 3.73 gears and hopefully a posi and thought that I might have better luck finding one from a 4 wheel drive. If I can swap the axles from a C10 into the K10 axle it will widen my search. If anyone has a lead on one within 100 miles or so of Bryan,Tx , let me know .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 11-24-2010, 12:15 AM   #2
GMC91
Always trouble
GMC91's Avatar
Re: 73-80 12 Bolt question
The should be the same except the axle bolt pattern. Which you already know you will need to swap.
91 Silverado Regular cab, 2wd, swb-project truck
97 Silverado Extended cab, 2wd, swb-driver
GMC91 is offline   Reply With Quote
Old 11-24-2010, 01:22 AM   #3
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Too bad you're not closer to FL. I have exactly that combination of '83 (I think) axles sitting around doing nothing. 3.73's with a locker rear. :/
lindstromjd is offline   Reply With Quote
