11-24-2010, 03:37 AM | #1 |
Pulling a cab off
I am mid way thru tear down and want to pull my cab off. What is the best way to do it? Also I have seen some pics of cab stands that will tilt to allow access to the under body. Anyone have some "how to" instructions for making one? Dimensions and what not? I have attached a few pics of my truck, and will eventually start a build thread.
11-24-2010, 07:10 AM | #2 |
Re: Pulling a cab off
Engine crane worked for me. I made a stand that rolled back onto some tires, worked great. Still have it somewhere. I used a 2 ton jack to lift the front of the stand then slid it around the shop when needed.
11-24-2010, 09:29 AM | #3 |
More Cowbell....
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
11-24-2010, 12:39 PM | #4 |
Thanks a ton !
How about you go over and introduce yourself, build me up, that way I don't have to brag about myself later. |
11-24-2010, 12:45 PM | #5 |
Where's my beer?
I pulled my cab over the bare front end with 4 people. No engine or anything in front of it. I set it on a pallet that I put 4 casters on so I can roll it around anywhere I want. Unfortunately, that's all that's happened, rolling it around the garage.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
11-24-2010, 06:21 PM | #6 |
you want a flipper so you can access the floors.
11-24-2010, 06:27 PM | #7 |
Agreed, just need to make or buy one.
11-24-2010, 06:57 PM | #8 |
VERY easy to make, think of a sleigh. I'll look for mine tomorrow and send pics. I used 1 X 1 1/8 wall, less then a buck a foot.
made the supports out of some old 1/4 flat stock i found at a metal supermarket. make a big hole for adjustment and weld another piece of flat onto a nut. |
11-24-2010, 07:02 PM | #9 |
Thanks. I look forward to the pics. This forum ROCKS!
11-24-2010, 10:36 PM | #10 |
11-24-2010, 10:53 PM | #11 |
Cruzin
here is my fliper
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
11-25-2010, 02:06 AM | #12 |
Big Red - Now its a SWB!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
11-27-2010, 02:54 AM | #13 | |
Moderator
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
