Old 11-26-2010, 09:41 AM   #1
jasons
not enough hours in the day
jasons's Avatar
74 front clip swap question
I have a lead on a good front clip (hood, fenders, grille, radiator support) from an 85 2 wheel drive that I would like to put on my 74 4x4.
Will the newer clip bolt up without any problems, I assume the radiator support will need to be changed also?
jasons is offline   Reply With Quote
Old 11-26-2010, 10:10 AM   #2
87 chevy silverado
Re: 74 front clip swap question
the hole front sheet metal fenders, hood, radiator support also the wiper arms
87 chevy silverado is offline   Reply With Quote
Old 11-26-2010, 10:15 AM   #3
LONGHAIR
I'm pretty sure that it can be made to work, but there are a few considerations. The main things are the hood hinges and "cowl screen".
The hood of the newer truck is longer, eliminating the seperate cowl panel from the older truck. This would be a simple un-bolt and remove deal, except the hood hinges are different too. The older model had the hinges/springs bolted to the fender as a complete unit. The newer ones are seperate. The spring still mounts to the fender, but the actual hinge mounts to (and through) the firewall.
I'm sure that there are wiring issues too....
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 11-26-2010, 10:22 AM   #4
Dalaigh
Canadian Trucker
Dalaigh's Avatar
I think you have that backwards, the 73-80 trucks have the longer hoods, and the 81-91 trucks have the shorter hood with a cowl below the windshield.
Dalaigh is offline   Reply With Quote
Old 11-26-2010, 11:30 AM   #5
jasons
jasons's Avatar
I'll have to go take a close look at it tomorrow. I knew the hinges were different, but didn't realize the newer ones mounted through the firewall. I was hoping for a simple bolt on swap.
Old 11-26-2010, 12:05 PM   #6
87 chevy silverado
for the most part it is
Old 11-26-2010, 04:50 PM   #7
LONGHAIR
You are right, the bolt-on cowl actually covers part of the hinge mounting.
Old 11-30-2010, 10:58 AM   #8
jasons
jasons's Avatar
I took a quick look at the 85 cab. It looks like the cowl on the 74 will need to be cut to accept the 85 hood hinges and the wiper transmission changed to make the swap work. Shouldn't be too difficult, just have to wait for spring.
Old 11-30-2010, 11:41 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
78 and 89
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
