Old 11-26-2010, 11:23 AM   #1
JesseSimon
Asks alot of questions
JesseSimon's Avatar
I'm needing some help...
It's about 30 degrees out right now, I go to crank up my truck and after pumping it furiously as I always do in the cold, it fires up.....however......it is screaming like the pedal is to the metal and I can't get it to stop. The throttle cable isn't stuck, nor the pedal. What could be causing this?
MY STABLE:
'66 C10 LWB turning it into a shortbed stepside
'77 LWB (my daily driver).....oh its a FORD ahhhhh!
'07 MAZDA 3 (the wife's ride)
JesseSimon is offline   Reply With Quote
Old 11-26-2010, 11:38 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: I'm needing some help...
Check the choke or sticking butterflies.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-26-2010, 11:46 AM   #3
JesseSimon
JesseSimon's Avatar
Bingo! Choke was stuck. Thanks!
MY STABLE:
Old 11-26-2010, 12:37 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
U R Welcome...
Articles-
"Refining Sierra"
Old 11-26-2010, 01:26 PM   #5
PRattenbury
Ya know, if the choke and everything is set up right, it should take one pump of the pedal to set the choke, turn the key, and you're running at high idle. I have no choke right now, so I have to pump several times... might wanna consider some adjustments.
PRattenbury is offline   Reply With Quote
