Old 11-26-2010, 11:39 PM   #1
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
What is this pipe?
Was looking through my engine and found a pipe I don't know the purpose of. It's just a metal pipe that runs from my exhaust manifolds to the air snorkel, pipe is the red circle and where it hooks into the snorkel is where the arrow is....what is it for? and why does my exhaust want to be routed into my air supply?
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 11-26-2010, 11:42 PM   #2
85burb
85burb's Avatar
Re: What is this pipe?
Heat riser for cold start. Does not suck in exhaust. It should have a heat sheild it draws fresh air over hot manifolds and into intake.........I think....
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 11-26-2010, 11:46 PM   #3
babyJay
Arrived on a Pale Horse
babyJay's Avatar
correct. It's a cold weather feature.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 11-26-2010, 11:51 PM   #4
THE "10" SILVERADO
Does this really effect the engines performance a lot in cold weather? Just wondering because if I switch to a open element air cleaner will I need to rig this to route the hot air into the new cleaner?
Michael
Old 11-26-2010, 11:58 PM   #5
85burb
85burb's Avatar
How cold are we talkin? Like -15 or 30 degress. I dont have one i just have reg open air type and as long as the choke works it starts. The coldest i have tryed is 30-35 deg or so.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 11-27-2010, 12:00 AM   #6
Benelli
Watchin the rust grow
Benelli's Avatar
I Just started mine in -20F the other day. I have an open element air filter too.
As long as you have a proper choke set up you shouldn't have any problems.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 11-27-2010, 12:02 AM   #7
THE "10" SILVERADO
Then I don't think I will need it....I don't remember a - temperature in Texas in as long as I can remember.....was this just a stock thing? Because I'm just wondering why they had that in there when it was shipped to Texas where we really don't need it...unless it was just a standard thing.
Michael
Old 11-27-2010, 12:07 AM   #8
85burb
85burb's Avatar
Just map quested you and i would say throw it in trash. If carb is adjusted right should have no problems. Sure it is an emissions joke.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 11-27-2010, 01:48 AM   #9
pig rig
pig rig's Avatar
liven in texas you shouldnt need it
what its idea was to help keep the carb from develope fuel dropout(freezing gas) and fouling plugs at low temp.
how it works is it puts warm air down through the carb keeping it from freezing as your going down the road once the engine has warmed up the flap in you aircleaner closes off that inlet and opens up for cooler air and to gain better fuel econmy
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 11-27-2010, 10:51 AM   #10
babyJay
babyJay's Avatar
I wouldn't throw it in the trash. It's probably a part someone in Cali needs. Ebay that sucker.
Jason
89 R3500 CC SRW
