Old 11-27-2010, 07:27 AM   #1
wardee1977
15x10 wheels on lowered '77
I recently purchased a nice '77 shortbox 2wd. I am going to be lowering it this winter. I am probably going with a 2.5/4 drop kit. I want to run 15x10's all the way around with 295/50-15 tires. The wheels I have been looking at are a 4" back space. Just windering if I will have any rubbing issues or if it is possible to go any lower. Say like a 4/6 or a 3/5 or something like that. Thanks very much for any info, and if anyone has any pics of a truck like this, please post.
wardee1977 is offline   Reply With Quote
Old 11-27-2010, 12:53 PM   #2
AceX
>130dB Moderator
AceX's Avatar
Re: 15x10 wheels on lowered '77
In the front, the 295 will rub and good. Even a 275 will have issues. I run a 255/60/15 in front when I had 15x10 all around. Also, the tire will stick out from the wheel well front and rear with the 295 I believe. Just another thing to consider.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 11-27-2010, 09:14 PM   #3
wardee1977
i found this pic. This is the look I am going for. It doesn't say, but I think he is running 295/50-15 tires. Not sure of the backspacing either.
http://67-72chevytrucks.com/vboard/s...ighlight=15x10
Old 11-27-2010, 09:40 PM   #4
Low84
Low84's Avatar
15x10 Centerline Coronas
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 11-28-2010, 10:09 AM   #5
wardee1977
looks nice! What size tires do you have there? And hw much drop do you have also. Looks low, I like it.
Old 11-28-2010, 03:36 PM   #6
Low84
Low84's Avatar
Thank you. The tires are 265/50, the drop is just cut springs but if I had to guess it would be right around 5" drop. Never rubbed, but the crossmember does become an issue as it's pretty low to the ground.
Old 11-28-2010, 04:04 PM   #7
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I had the idea of putting these 295/50/15 wheels on my 78, but to me they do not fill up the wheel well enough. This is with a flip kit in the rear and 2 or 3 leafs removed. The axle is about 3/4 to 1 inch from the frame rails in this pic.
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 11-29-2010, 09:22 AM   #8
wardee1977
Those don't look like 295's or 15x10 wheels. What you have there definitely does not fill up the wheel well.
I found this pick on here. He has 15x10's with 295/50/15's and a 2.5/4 inch drop. I believe the wheels are 4 inch backspacing as well.
Old 11-29-2010, 11:46 AM   #9
3r!c84
Badass
3r!c84's Avatar
315 rear tire. on 17x9.5 rim
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-29-2010, 12:02 PM   #10
wardee1977
That looks sweet! Too bad I can't afford 17" wheels.
Old 11-29-2010, 12:06 PM   #11
Tony_SS
Tony_SS's Avatar
That is my old c10 and I never had any rubbing issues at all with a 3/4 drop.
Tony_SS is offline   Reply With Quote
Old 11-29-2010, 10:46 PM   #12
85silverbeast
85silverbeast's Avatar
I wonder if there would be any problems with a 275/45-20 tire in the front with a 3" drop?
85silverbeast is offline   Reply With Quote
Old 11-30-2010, 08:44 AM   #13
wardee1977
Your wheels are tucked in pretty good. I kinda wanted min to be out more. Kinda like the sidewalls to be flush with the fenders.
Old 11-30-2010, 08:48 AM   #14
ECU PIRATE
ECU PIRATE's Avatar
I have a set of 15 X 10 wagon wheels I was planning on throwing on the back. Any issues with a 6" drop in the rear?????
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 11-30-2010, 09:16 PM   #15
coater
TonySS, The black c10 in the picture has a 3/4" drop? Do you remember the backspacing?
coater is offline   Reply With Quote
Old 11-30-2010, 09:24 PM   #16
coater
I purchased a set of 15x10 chrome corvette rally's that I'm going to powdercoat black chrome,so I'm interested in this thread. Haven't purchased tires yet.
Old 12-01-2010, 08:54 AM   #17
silvereagle07
silvereagle07's Avatar
Here is an old pic of my buddies truck. 15x8 front and 15x10 rear corvette rallye's. It's lowered with 2.5 inch spindles/one cut coil in front and a flip kit in the rear.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 12-01-2010, 08:59 AM   #18
Tony_SS
Tony_SS's Avatar
Not sure.. I think around 4.25" or 4.5". They were Rebel Racing wheels, I got them off of ebay for about $80 each. Yes it had a 3/4 drop.
Old 12-01-2010, 11:34 AM   #19
wardee1977
I think I should be safe with a 2.5-3/4" drop and 4" backspace wheels with the 295/50-15's. I was looking at these wheels below. I guess the worst that could happen, is that I have to buy smaller front tires. I was kinda hoping to have all 4 the same. I could just get 2 mounted and put them on the front to see if they rub before I buy the other 2 tires.
http://www.summitracing.com/parts/BRW-909B515340/
