Old 11-27-2010, 01:56 PM   #1
Wvgearhead
HillBilly 53 build
I have been watching everybody elses builds on here and thought I would finally post some pics from mine. I drove to alabama to pick up this 53 for $800 from a friend. I have put a mustang II under the front and have started on the rear suspension. Drivetrain will be a ~450Hp 350 with a T56 6 speed and a 8.8 rearend from a f*** Exploder.
Name:  front suspension1rs.JPG
Name:  front suspensionrs.JPG
Name:  rear suspension2rs.JPG
Name:  rear suspension1rs.JPG
Name:  rear suspensionrs.JPG
Wvgearhead is offline   Reply With Quote
Old 11-27-2010, 02:19 PM   #2
sgtusmc
sgtusmc's Avatar
Re: HillBilly 53 build
Wow man, looks like a great start...with exception of that flat tire
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 11-28-2010, 01:12 AM   #3
Blanco
looks good
Blanco is offline   Reply With Quote
Old 11-28-2010, 11:12 AM   #4
Wvgearhead
Thanks guys, Yeah that flat tire made for a good push to get it in the garage. The rearend that was under it, connected to that flat tire, was a 12 bolt out of a 79 chevy 2wd. So it was too wide and had to come out anyway.
Old 11-28-2010, 12:29 PM   #5
Wvgearhead
Heres somemore pics of the way it looked when I unloaded it off the trailer from its long trip from Alabama to its new home in Wv.
Old 11-28-2010, 12:39 PM   #6
1lo67
1lo67's Avatar
looks good...looks like you got a good deal @ $800.00 bucks. keep the pics coming.
1lo67 is offline   Reply With Quote
Old 11-28-2010, 01:01 PM   #7
Wvgearhead
Heres a pic of a buddys 49 wearing its original paint.
Old 11-28-2010, 09:57 PM   #8
Wvgearhead
Another friends truck, hes running a caddy front sub frame and a 455 big block.
Old 02-20-2011, 11:29 PM   #9
Wvgearhead
Thought I would finally show a little progress. I have C-notched the frame using a peice of 4" pipe and have finally settled on the setup for the rear suspension. I still havent welded up brackets for bags or shocks but will throw some pics up of that when I get it done.
Old 02-20-2011, 11:41 PM   #10
Wvgearhead
Old 02-20-2011, 11:45 PM   #11
Wvgearhead
Old 02-21-2011, 01:20 PM   #12
72Mountaineer
72Mountaineer's Avatar
Nice build. Where is the front end from?
72Mountaineer is offline   Reply With Quote
Old 02-21-2011, 02:04 PM   #13
Wvgearhead
Tci
Old 02-21-2011, 02:19 PM   #14
Wvgearhead
Tci
Old 02-24-2011, 03:03 PM   #15
troy54gmc
troy54gmc's Avatar
lookin good hillbilly. are you planning on putting your fuel tank in the rear frame section behind your axle? the reason im asking is i read on here i cant remeber what thread it was but the guy had done all the math to figure this out, he said when you c-notch the frame like you did you lose like 60 to 75% of the strength in the frame behind the notch. i wish i could remember what thread it was cause i seen alot of guys do the notch like that. anyways just thought i would throw that in. Charleston Vw. Hey i got kin that live in barberville and my mom was born in charlseton. know any Tocks or McCoys ??
troy54gmc is offline   Reply With Quote
Old 02-24-2011, 03:15 PM   #16
GhostTown
GhostTown's Avatar
I'm 225 lbs and can stand on that tank with zero flex on the frame. It flexed like a SOB before the shock tower was welded in though.
GhostTown is offline   Reply With Quote
Old 02-25-2011, 12:04 AM   #17
troy54gmc
troy54gmc's Avatar
Ya Ghost i totally agree. when the guy explained it he even showed diagrams of braceing it. i believe the way you welded that plate your crossbars are welded to strengthen yours up alot. dang i wish i could remember that thread it was in. like i said i seen a ton of people do c-notchs that way. i think with braceing it would work great.
Old 02-25-2011, 05:15 PM   #18
Wvgearhead
Troy, I have heard of a couple McCoys but none ring a bell. I do plan on putting a tank back there, But I am also going to build a frame out of 2"x2" for what I am doing for the bed floor, which will also give it a little backbone. Really with the 3/16th stiffners I welded in the center of the frame before I boxed it, I wouldnt worry about it. I can put a lot of weight on it, even supported at the rear of the frame and it doesnt flex.
I am going to try to build my motor mounts this weekend and put them in, but I may run over to my buddys to help get him started on his 46 chevy truck.
Old 05-13-2012, 09:16 PM   #19
Wvgearhead
Thought I would post some progress.
Old 05-13-2012, 09:38 PM   #20
Wvgearhead
Motor mounts.
Old 05-13-2012, 10:09 PM   #21
Wvgearhead
Some more, even had the ol lady welding on the box plates.
Old 05-13-2012, 10:12 PM   #22
Wvgearhead
Some more....
Old 05-13-2012, 10:21 PM   #23
Wvgearhead
And more....
Old 05-13-2012, 10:29 PM   #24
Wvgearhead
A little paint goes a long way.
Old 05-13-2012, 11:13 PM   #25
Wvgearhead
Few more.
