Old 11-28-2010, 11:56 AM   #1
blazer2007
boxing or stiffening frame without welding
can you box a frame without welding using plates and bolts etc.Its on a blazer
blazer2007 is offline   Reply With Quote
Old 11-28-2010, 01:44 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: boxing or stiffening framw without welding
Sure, why not? If you use sections of channel and bolt them in it will brace the frame. Of course it would be better to weld it, but it can be done.
Why, does it need more support?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-28-2010, 02:51 PM   #3
suville
suville's Avatar
Glad someone asked this and I hope there will be more input on this. Been following the "Make it Handle" thread by Rob-Nolimit and this is hopefully an alternative to welding everything, seems you would want "some" flex the reason aircraft is rivited constriction is for that very reason otherwise you could end up with fatigue cracks, whats ya'lls thots on this? Thanks
suville is offline   Reply With Quote
Old 11-29-2010, 11:34 AM   #4
blazer2007
I thought with the bigger engine with the c notch wouldn,t hurt.
Old 12-01-2010, 12:40 AM   #5
Gobbles
Gobbles's Avatar
Re: boxing or stiffening frame without welding
I was always under the impression that welding the frame is frowned upon because it is tempered steel, which is why with flip kits and such they install bolt on reinforcements. This obviously does not apply to the weld in C-Notches but I don't know much about those. For all my welds, I have added bolt in reinforcing plates, it might be overkill but it beats a broken frame.
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
