02-02-2002, 11:34 PM | #1 |
strikers
Both my doors rattle quite a bit. I think its because the strikers are missing the plastic collars that go around them. has anyone had this problem? If it is the collars where can a get new ones? One more question - The drivers door sags about 1/4 to 1/2 inch on the side opposite the hinge. Is it O.K. to justmove the striker up to cure this.
Sorry too many questions! Thanks in advance! ------------------ '84 1\2 ton swb, 350 5\7 drop just sold '64 1\2 ton 4\4 drop with built 350 (my toy)
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
02-04-2002, 09:06 AM | #2 |
the strikers you can get in the HELP section of any known auto parts store. as far as the door sagging you will probably need to repair the hinges. it aint hard to do just pop out the old ones and bushings and the hinge kit, also sold in HELP section, has new bushings and pins. if you dont fix them all you will do is where the new strikers out. fix it right and you will be happy with it and will last ALOT longer. good luck
------------------ 85 C10 350/700r4 COMPCAMS XE262 "K" kit compcams magnum roller rocks (SOON I HOPE) 91'BURB GRILL CONVERTION HOLLEY STREET DOMINATOR INTAKE EDELBROCK 1406 COMP. SERIES CARB. HYPERTECH POWER COIL FACTORY HEADERS MAGNAFLOW CAT/MUFFLER/3in. EXHAUST 3.42 REAR GEARS PROTHANE SUSPENSION-TOTAL KIT DUAL 13" ELECTRIC FANS and still going "thats my toy" Jeff Dodson Angleton,Tx.
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
