Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 12-02-2010, 10:04 AM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Need help with winshield scratches
Is there a product or method out there to remove what looks like scratches on my windshield? It looks like someone took a scotch pad to the windshield at one point for some weird reason and when the sun is directly in the face it is very hard to see out the windshield.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 12-02-2010, 11:06 AM   #2
cdowns
cdowns's Avatar
Re: Need help with winshield scratches
new winshields are readily available from local glass company and cheap and normally the best longterm solution
Old 12-02-2010, 06:46 PM   #3
softballnrd27
I will replace it but for now I just want to try and get rid of the scratches for the time being.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 12-04-2010, 02:33 AM   #4
nbpro
Glass polishing kits come with the necessary components to polish out front windshield scratches and hairline cracks with an electric drill. Worthy candidates for the procedure are any scratches or cracks that are shallow enough to not catch a fingernail.
http://www.gadgetjq.com/windshield_scratch_removal.htm
nbpro is offline   Reply With Quote
Old 12-08-2010, 03:21 PM   #5
nerphin
nerphin's Avatar
used this kit from eastwood on my back window that had marks from carrying stuff in the bed. worked well for me, and a lot cheaper than replacing the whole unit.
it comes with a drill bit attachment, but i would recommend using an angle grinder for leverage and stability.
nerphin is offline   Reply With Quote
Old 01-20-2011, 03:21 AM   #6
Livrat
Member #1049
Livrat's Avatar
I have used cerium oxide.. found at a local rock shop..
Or...
http://glasspolishshop.com/cerium_oxide
Then add a little water to make a paste out of a small take a good polishing wheel on a grinder and polish away.. be prepared to spend quite some time on it.
I won't ever do it again, too time comsuming, when finished it will look good but watch out at the first rain.. you will have grooves and valleys where you polished out the scratches, the wipers will pass right over them leaving streaks.. (Unless you polish the entire windshield flat..)
Its way less work and way more cost effective to just spend the $100 on a new windshield..
Livrat is offline   Reply With Quote
Old 01-20-2011, 08:33 AM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Scratch specific search within the Detailing section using "glass" as the keyword:
http://www.67-72chevytrucks.com/vboa...ighlight=glass
Here's a quick link to other threads that have been requested in the detailing section referencing similar issues:
http://www.67-72chevytrucks.com/vboa...archid=2106225
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
