Old 12-02-2010, 11:20 PM   #1
HTX86chevy
HTX86chevy's Avatar
Question Yet another Gauge cluster question...
ok, so i was playing around with the gauge cluster today trying to add a small custom touch to the gauge faces by adding the white face gauges with blue led bulbs that one of the members here recommended awhile back.
here is my question: What does the wire that is attached to this bulb plug into???
HTX86chevy is offline   Reply With Quote
Old 12-02-2010, 11:39 PM   #2
78cheyenne292
Re: Yet another Gauge cluster question...
is that bulb the main dash light bulb.. my blinker indicators work and mt highbeam indicators work but other then that i have nothing.. iv looked around a little but have not yet figured it out.. if you could help us both out that would be great!
78cheyenne292 is offline   Reply With Quote
Old 12-02-2010, 11:51 PM   #3
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
That "WIRE" is actually a clear piece of somewhat flexible clear plastic that has a black sheath over it. And what it's for is the "FIBER-OPTIC" light for the ashtray.If you were to pull the bulb out of the base and then tape the base face to face tith a small penlite flashlight, turn it on and look at the end of the fiber optic filiment you'll "SEE THE LIGHT"
Don't smoke or use your ashtray for anything? then don't worry 'bout it.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 12-02-2010, 11:59 PM   #4
HTX86chevy
HTX86chevy's Avatar
thanks alot ble 'burban!
@78cheyenne292- check your harness that connects to the stereo. Sometimes if you cut the wires to connect an aftermarket stereo you'll have that prob. Also, have you removed the bulbs to check if they"re burned out? Also could be a bad contact on the "green and copper thingy" on the back of the cluster .
Old 12-03-2010, 12:45 AM   #5
79bonanza
where did you get those white faced gauges man, they look awsome
79bonanza is offline   Reply With Quote
Old 12-03-2010, 01:09 AM   #6
Telecasterjoey
Gotta put up a pic with the white cluster installed im really digging it!
Telecasterjoey is offline   Reply With Quote
Old 12-04-2010, 02:00 AM   #7
78cheyenne292
yeah i checked the bulbs they look good.. the guy i bought the truck off of installed the last stereo and obviously didnt no what he was doing. there wasnt a stereo in it when i got it just a mess of wires (a real big mess) the hole wiring on the truck was junk.. i rewired a new deck in completely independently so what wires should i look at for the dash. i have a stray power wire coming from my fuse bocks with a snap connector its only about 5 inchs could that be the power wire for the cluster.. what wires should i look for and were do they plug into the cluster for the lights.. thansk for the help guys.. dont wanna get a speeding ticket at night haha its only a inline so that shouldnt be much of a concern anyways haha..
Old 12-04-2010, 02:43 AM   #8
qu1cks1lver56
qu1cks1lver56's Avatar
LED bulbs aren't like incandescents, they have a power and a ground, check to make sure the bulbs are in the right "direction"
qu1cks1lver56 is offline   Reply With Quote
