www.73-87chevytrucks.com
![]() Join Date: Dec 1999
One Piece Window Conversion Kit for '67-'72 GM Trucks *
![]() One Piece Window Conversion Kit for '67-'72 GM Trucks ![]() Window Conversion Kits for: Chevy Suburban, Chevy Blazer, Chevy C-Series. Comes with everything to convert two(2) doors: glass, run channel, inner and outer scrapers, and all hardware to eliminate the vent windows. ![]()
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by N2TRUX; 02-07-2011 at 10:29 AM. |
![]() Join Date: Nov 2007
Re: One Piece Window Conversion Kit for '67-'72 GM Trucks
You have pics of these installed on a 69-72 Blazer?
Posted via Mobile Device |
Trying to get some. 67-72 Convertible Blazer kits are $50 extra.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Should have some tonight or tomorrow of the Blazer kit installed.
optomistic ah-so
Dang!!! That's the good looking ones, too...no "triangle to weld in" insert at the front.
Hmm...hmm...I need channel runs, too (can you tell I'm trying to convince myself?) How long will this group buy be held open before you place the order? I can't do it before recovering from the holidays...and what tints are offered?
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. ![]() Last edited by CSGAS; 12-08-2010 at 10:37 PM. Reason: last Q |
well, this isn't a Group buy so, forever....
optomistic ah-so
Ahh!!! That could be a lot more convenient then!
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. ![]() |
Blazer door pics:
in all honesty, does it fit "well" enough to where it is not a major pain to install? i have bought two kits and returned them both to other manufacturers because of fitment issues
TNT-MOTORSPORTS
Same question as above , that is the reason I wasnt doing 0ne piece glass , although I really would like to, Also is there optional grades of tint or is there only one option.
Since I have no idea what your mechanical abilities are, or what tools you own thats hard to answer. This is one of thee best designed kits on the market. With that said, it will require a certain amoint of mechanical skills to install. If you posses those skills you should be fine. If not, you may want consider professional help
There are a series of videos OPP is putting together for installation steps that will be in my catalog for a visual of the installation process. 67-72 kits are available in clear, green tint and grey tint ($20)
how many of these kits have you installed and how long does it take you? and when you are done, does the window go up/down smoothly and seal out the elements, and not rattle?
#13 |
mechanical ability is fine, what i had a problem with the other kits was i would have had to cut them up so much to make them work that i could of built it easier and cheaper than redesigning the whole thing. i am the type of person that likes to buy nice stuff and have it fit. i understand that the doors are fourty years old and have been to hell and back, but the other kits were not even close. just wanted to know you opinion of the kit since you have put one in
#14 |
TNT-MOTORSPORTS
I got an AWESOME set of tools ........ My Dad was aTV repair man .... LOL
#15 |
#16 |
I have only installed 6 sets of the flat kits. First set took me about a day per side, this was the first design in an aftermarket door, 4 years ago. They got easier the second time. The extra tech tips included in the instructions covered all of the issues I had the first time around. Last one was about a year ago (new design), and I helped a friend install them, it was about 1.5 hours per side.
Another buddy took his to a body shop and he is paying them to install them, instead of me. I went by there last week to get something painted and they apparently aren't following the directions as they wanted to buy a rear guide from me and re-engineer the kit. This kit doesn't use the rear guide. They have had it sitting outside for over 3 months because they don't know how to install it/read the instructions. The majority of the people that I have had complaints from have done this. The ones I have installed roll up, and seal just like factory and they don't rattle.
#17 |
to help us/me, could you post the instructions...
#18 |
They are in the link above that goes to my catalog, and hot linked under Window Manual instructions, but this is the direct link.
http://www.73-87chevytrucks.com/tech...nKit_67-72.pdf
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 12-18-2010 at 05:27 PM. |
#19 |
![]() Join Date: May 2007
Is there more than two revisions of this kit?
#20 |
They are currently on the 5th revision.
See below for Video installation guide Also linked in my store (part 1-4 currently more parts added as they are created)
#21 |
Those 1 piece windows look pretty slick. Most of my money is going to the small things to keep me up and running, but once I get some more cash this looks like a great addition to my 72 k5.
Thank you god for all your blessings! My mini build (I had a great starting point) http://67-72chevytrucks.com/vboard/s...d.php?t=440743 |
#22 |
What revision are you speaking of?
R.I.P. Killer 71 10/26/07 |
#23 |
Who was this directed at and in what context? Not sure what you are asking or how to answer.
#24 |
Re: One Piece Window Conversion Kit for '67-'72 GM Trucks *
i'm at the point in my build where we need to mock our window kit up. We will be going with power windows and would like to go with a one piece kit. Their seem to be some fitment issues from the research i've read on this forum. You stated in the above thread that "they are currently on their 5th revision", i was simply asking what that revision was?
#25 |
The latest revision included an improved door stop and adjustable rollers to fine tune the angle of the glass in aftermarket doors.
