Old 02-04-2002, 09:25 PM   #1
MJN
MJN's Avatar
Question sway bar ?'s
I put a 6" suspension lift on my '74 3/4 ton pick up and the sway bar in front smashes the bushing on one side. It has the heavy duty sway bar and has all the HD stuff except the NP203. My friend put a 4" on his '75 and had no trouble with the sway bar but mine is at too much of an angle. Anyone make lowering kits for the sway bar? Thanks
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 02-05-2002, 02:09 AM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
www.offroaddesign.com sells a sway bar disconeccet
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 02-05-2002, 10:11 AM   #3
GMC_Legacy
Post
just remove the sway bar all together. i have the same amount of lift as you and i dont mind driving it without a sway bar, the springs are arched enough to really not need one. give it a try, its the cheapest route. if you dont like it, im sure someone makes a lowering bracket, or you might have to make one.
GMC_Legacy is offline   Reply With Quote
Old 02-10-2002, 09:40 AM   #4
u2slow
Web Wheeler
u2slow's Avatar
Wink
My 4x4 crewcab still has the stock springs, and I took out the swaybar altogether. Noticeable improvement off-road. Negligible difference on-road.
'66 C10 longstep - Clifford equiped
'84 C20 Suburban 6.2L - awaiting 4x4 conversion
'91 V3500 Crewcab - awaiting diesel swap
u2slow is offline   Reply With Quote
