Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-08-2010, 02:06 PM   #1
81ShrtBox
MadMan
81ShrtBox's Avatar
Help/Input needed
I recently did a Vortec swap in my 81" Shortbox.
99" yukon heads on a 96" suburban block(heads decked, valves polished, new seats, lil-pocket port clean up)
Beehive springs
Will Hoites 270 Roller cam .495 intake .218@50 and .502 exhaust .224@50
thin head gaskets
Headers
Summit Race mufflers with 2.5" pipe slight angle before rear end
KMJ Performance 65,000volt HEI distributer
Edlebrock 750 vac sec
ebay Performer RPM replica intake
trucks drives and runs great, the Will Hoite camshaft sounds mean as hell. But when I get on the gas it jumps forward then falls on its face... does a means burnout... just cant get the dam thing to perform.
It acted better after I replaced the stock distributer, but still isnt 100%. I'm changing the fuel pump, and then the roller lifters are next( I re-used the old ones). I have tried changing to platinum plugs, carb is like new... even checked to make sure I had 12v to the coil...I'll try changing the alternator because i want everything new anyway... if the fuel pump and alternator dont change the problem I'm yanking the engine and starting over with another combination...
This one will be Competition Cams, MSD Electronics and an Edelbrock intake... I looked at alot of different reviews with people having excellent results with this same combo(est400hp/380-400ftlb torque... but its giving me the blues
81ShrtBox is offline   Reply With Quote
Old 12-09-2010, 01:10 AM   #2
Captainfab
60-66 Nut
Re: Help/Input needed
Have you set your total timing? Where is it at? What do your plugs look like? Did you make sure there is sufficient retainer to valve guide seal clearance?
Old 12-09-2010, 09:26 AM   #3
swb85
On a budget like Fred Sanford
swb85's Avatar
If you slowly roll into the throttle instead of smashing it does it still fall on it's face?
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 12-09-2010, 04:50 PM   #4
81ShrtBox
MadMan
81ShrtBox's Avatar
Plugs looked good(one had fouled and was wet from the carb not being set right), the retainers-springs I used were supposed to be drop in installation. GM Vette Z06 beehives from summit with Comp Cams retainers... simple drop in installation. A buddy of mine is a ASE Certified Technician.. he set and double checked my timing... told me dont touch it.
If it slowly roll on the throttle it still breaks up around 4-5,000 rpm..
