Old 12-09-2010, 09:26 PM   #1
mac72
Cab fitment
I stayed after work today to test fit my cab & found that it hits the tranny on the pinch weld.I dont remember reading any posts about anyone running in to this problem, Just curious what you guys are doing w/ it.My cab is a '72w/ a 4l65e 3 deg. down,SD crossmember w/ ls mounts & just removing the pinch weld wont be enough,might need to modify the trans tunnel. Any suggestions?
mac72 is offline   Reply With Quote
Old 12-09-2010, 11:28 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Cab fitment
I originally thought I was going to have that problem with my '68 and a 200-4r...but then I wound up changing form the ECE mounts to a combo OEM/TransDapt setup which moved the motor forward some...and cured my problem.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-10-2010, 06:46 AM   #3
67C10BUB
67C10BUB's Avatar
Re: Cab fitment
I used the ECE mounts and had zero fitment issues. I even have a low hump cab. Is the 4l65 that much bigger than the 4l60?
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 12-10-2010, 08:24 AM   #4
mac72
Re: Cab fitment
I'm using one of those aftermarket crossmembers that is already made for a ls & it doesnt use adapters.I'm gonna call suicide doors today & see what they have to say about it.
The 60 & 65 use the same case
Old 12-10-2010, 06:51 PM   #5
68GMCCustom
Re: Cab fitment
ECE mounts place the engine farther forward, just ahead of where a sbc should be. Sounds like your mounts place it closer to the 6cyl position. How does the front of the motor line up with the crossmember mac? 1" Over, 1" behind, etc.?
Kurt -
Old 12-11-2010, 11:14 AM   #6
mac72
Re: Cab fitment
I'll chk. today.Called SD yesterday & they told me that they use a high hump when they do them.I think I'm gonna have to change my coil location also,I had planned on the back of the head mounts but I dont see it happening now.
1 stp forward 2 steps back!!!
Old 12-11-2010, 02:27 PM   #7
68GMCCustom
Re: Cab fitment
I tried mine it that location and decided it was going to be too much work (right now - as no bodywork other then filling the fuel hole is planned) and placed the motor 1" behind where a sbc should be. Yours is more like 4+" behind (I'm guessing here / -1" plates with motor mount stands in the 6cyl location).
I'd like mine to be in that location for handling/balance and traction reasons...just don't have the time or funds budgeted for that kind of mod right now. Might do it when I start paint and body in a year (gotta let bank acct recover ) or so.
Kurt -
Old 01-18-2011, 09:47 PM   #8
68GMCCustom
Re: Cab fitment
got any other shots of your motor and the fitment?
Kurt -
Old 01-18-2011, 11:43 PM   #9
78bronzechariot
78bronzechariot's Avatar
Re: Cab fitment
I mounted mine (4.8 truck motor and 4l60e) in the 6 cylinder position with "universal" adapter mounts and used a just a little persuasion with the good old ball peen. Painted it up and, worked just fine and didn't hurt a thing.
78bronzechariot is offline   Reply With Quote
Old 01-20-2011, 08:37 PM   #10
blazerboy72
Re: Cab fitment
I have mine in the 6 cyl location using pol tubular mounts with adapter plates. Even with a 4l80e I have plenty clearance with a low hump.
blazerboy72 is offline   Reply With Quote
Old 01-21-2011, 09:19 PM   #11
jmanthony65
jmanthony65's Avatar
Re: Cab fitment
Sorry.. A little off topic but WHAT is that in the background?! It looks awesome...
jmanthony65 is offline   Reply With Quote
Old 01-22-2011, 04:30 PM   #12
mac72
Re: Cab fitment
LOL Thats a POS monster truck I did some work on but the guy cant pay his bill!So there it sits. It does have one hell of a mtr. in it tho.The rice & canes are out back ,the little tires just let me get it in the bay!& yes I can personally attest it will pull wheelies!
Old 01-22-2011, 04:40 PM   #13
mac72
Re: Cab fitment
Well I'm not up to speed on the no hump,low hump,high hump thing but My cab is actually a 72 & would not clear so I ended up putting a high hump in it & it just barely has enough clearance.My floor never had a removeable hump & pinion angle might have a little to do w/ it.Thanks for everyones input
Mac
Old 01-22-2011, 05:32 PM   #14
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Cab fitment
I think it has something to do with the drop member placing your motor higher.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
