Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 12-10-2010, 01:19 PM   #1
chevyman95
chevyman95's Avatar
3 Front Ends- 77, 83, and 85
3 front ends 77= $225 83=$175 85= $275
1977 c10 included are the fenders, hood, core support, headlights, grille, radiator, drivers side inner fender and all the little pieces that go with that. I have a brand new fender to replace the passenger side damaged one. The only rust other than surface is at the bottom of the core support on the passenger side. The hood rust is just surface rust that will sand off. Other than that it is great. Has only been sitting on the ground for about a month or so
The 83 Front end has seen better days, no rust issues that I remember except maybe a little bit under the battery. This one was sanded down completely and someone tried to weld up the emblem holes and bondo them. Also some dents in the fenders. Came off my old truck
The 85 front end is the best of the 3, no rust issues and in great shape. No radiator on this one though.
I'm in norcross, ga
chevyman95 is offline   Reply With Quote
Old 12-12-2010, 01:49 PM   #2
lo72
Truck Junkie
lo72's Avatar
Re: 3 Front Ends- 77, 83, and 85
Have you got the headlight doors for the 85 front end? Does the grille have any cracks or broken tabs? How is the metal under the battery box? Is there any bondo in the fenders?
lo72 is offline   Reply With Quote
Old 12-15-2010, 12:05 PM   #3
chevyman95
chevyman95's Avatar
yes headlight doors are in good shape, grille has 1 broken tab, metal under the battery box is good, as far as I can tell there is no bondo in the fenders
Old 12-15-2010, 12:34 PM   #4
lo72
Truck Junkie
lo72's Avatar
I would like to come out and see them if possible, let me know when it would be a good time for you it would have to be on a weekend Thanks greg
Old 12-20-2010, 12:11 PM   #5
dabels23
dabels23's Avatar
Any chance you got a spare fan shroud off the 83 or 85
dabels23 is offline   Reply With Quote
