12-10-2010, 02:38 PM | #1 |
2003 z71 tranny problem
i just bought 1 2003 z71 for $1400 it was a deal i couldnt pass up the only thing is the truck wont shift into 3rd gear, it shifts into 1st and 2nd fine i was wondering if that would be the 2nd 3rd solenoid or if the tranny was just junk
12-10-2010, 02:49 PM | #2 |
Re: 2003 z71 tranny problem
Most likely it is your 3-4 clutch. Pull your pan and if it has clutch material in the bottom then is the 3-4 clutch. most common. I just bought a 96 sub for 500 buck with the same problem. Son put it on the bench and one hour later he was sticking it back in the suburban. Worked fine. DanO
1972 c10 SB 1968 c10 SB 1970 c10 LB 1971 k10 LB 1970 k10 LB 1972 gmc 2w LB Some projects, some should be. |
