Old 12-14-2010, 11:23 AM   #1
bigguy
painless wiring
Has anyone used a Painless wiring harness for their LSx swap? If so can you please tell me how you wired the fuse block ignition. My truck stays on after the ignition is turned off and key removed. I had to install a toggle switch to cut the power to that wire. i thought it might have been the alt. backfeeding, but i removed the wires from it and still the same problem. Any ideas?
bigguy is offline   Reply With Quote
Old 12-14-2010, 05:07 PM   #2
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Re: painless wiring
Sounds like you have constant power going into one of your ignition wires in the harness. Maybe you hooked up the wires to your ignition wrong?
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 12-14-2010, 05:53 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: painless wiring
It sounds like the power source you needed was a switched source, but it ended up on a hot lead. Doublecheck the ign wiring, throw a multi-meter on there and cycle the power. You should obviously see power cut when you key-off.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
