12-15-2010, 09:05 PM | #1 |
where are the c20 lowering parts?
have a 71 suburban c20 with 38k original miles and want to lower it with spindles/spring up front and ? out back. needs to stay 8 lug. it will be my tow rig. want to go 5"/7". any ideas? i know how the middle child feels now. left out. thanks, glen
my build threads, 68 pro touring, auto cross c10 (mid life crisis) http://67-72chevytrucks.com/vboard/s...d.php?t=464109 website http://www.sauersgarage.com/ |
12-15-2010, 09:20 PM | #2 |
Big Red - Now its a SWB!
Re: where are the c20 lowering parts?
You could run c10 drop springs and lower it, but that would drop your weight capacity for towing. What do you have in the back, coils or leaves? If you have coils in back you could use air bags to get the drop you want and keep the load cap, really you could do the same in front too. Another option would be to chop your front springs, that's what I did and it got me 3" lower. Now if you have leaf rear you can pull leaves or get your re-arched, or do an axle flip. Oh and with a 7" drop in rear you will need a c-notch, especially if you are gonna haul.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
12-15-2010, 09:23 PM | #3 |
thanks, its coil rear. i know i have to c notch the rear. i want to keep her 8 lug f/r. have stock hubcaps coming and want to put 16x10 and 16x8 steelies on it.
12-16-2010, 11:51 AM | #4 |
GMC Paul sells drop springs for 67-72 C20's. I think they are custom built for the order.
http://www.gmcpauls.com/67-72_d&s.htm 63-72 3/4 Ton Front Lowering Coil Springs Pair 4145722 For 67-72 3/4 ton trucks, Heavy Duty High Performance Front Lowering Springs Available in 1", 2" drop. Sold as a calibrated matched set. These are not cheap imported car springs like others sell these are custom made in the USA and are calibrated matched sets made specifically for the truck they will be installed on. $129.95 63-72 3/4 Ton Rear Lowering Coil Springs Pair 4145732 63-72 3/4 Ton truck Heavy Duty High Performance rear lowering springs. Available in 2", 3", 4", 5" or 6" drop. Sold as a calibrated matched set. These are not cheap imported car springs like others sell these are custom made in the USA and are calibrated matched sets made specifically for the truck they will be installed on. $129.95 This will not get you the 5" front drop you are looking at. Early Classic http://www.earlyclassic.com/catalog.aspx offers a front spindle conversion to change it over to 1/2 ton and a drop spindle. -20 ¾ to ½ Ton Conversion 2½" Drop Spindles Looking to convert your ¾ ton Truck to ½ ton front suspension? We are proud to introduce the only C-20 to C-10 2½" Drop Spindles available on the market. (disc brakes required). Over the years, we’ve had many customers with C-20 8-lug Trucks that would like to convert over to the better riding C-10 suspension and change their wheels to either a 5-lug or 6-lug bolt pattern. These new Conversion Spindles allow you to upgrade to C-10 front disc brakes on the ’60-’70 model Trucks, and give you the option of 2½" front Drop Spindles for the same price without having to change your tie rods and ball joints. Several options are available to change the rear suspension and axle as well, and our technical support staff is more than happy to explain the different methods and choices available for each Truck year and model. Give us a call, we’re here to help! Please post back what other solutions you end up finding....
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
12-16-2010, 12:06 PM | #5 |
67-72 parts collector,…
www.PerformanceOnLine.com sells C20 2.5" drop spindles.
(part# DS7187 FOR $399) Kinda pricey since all their other spindles are $228.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-16-2010 at 12:09 PM. |
12-16-2010, 01:22 PM | #6 |
thanks, i left a message at pauls. hope they call back. i want to keep it springs if i can.
12-16-2010, 05:22 PM | #7 | |
12-17-2010, 12:07 AM | #8 | |
I wonder if they are different from the ECE spindles as they require 1/2 ton brake rotors. Makes me wonder if they will still be 8 stud. http://www.performanceonline.com/196...P-SPINDLE-SET/ Here is what their website states: These hot items lower the front of your vehicle without affecting ride quality or suspension geometry and bolt directly to the original ball joints. Requires disc brake application. Please specify year and model. Use OEM ball joints. All spindles require heavy duty 1/2 ton rotors.
12-17-2010, 12:15 AM | #9 |
You should be looking at these:
http://www.performanceonline.com/197...P-SPINDLE-SET/ Click the drop down box for the C20 spindles. They keep your truck 8-lug.(part# DS7187 FOR $399 for drop spindles only) They are listed as 71-87 spindles. You guys converting 63-70 trucks,... you will need to change balljoints and tie rods.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-17-2010 at 03:22 PM. |
12-17-2010, 12:23 AM | #10 |
Board member Mulk lowered his 3/4 ton 'burb all with suspension components from POL,... including the C20 drop spindles.
He used this kit:http://www.performanceonline.com/196...-DELUXE-16682/ Look here: http://67-72chevytrucks.com/vboard/s...d.php?t=410371
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-17-2010 at 12:27 AM. |
12-17-2010, 09:40 AM | #11 |
thanks, i just checked it out. looks cool!
12-17-2010, 10:18 AM | #12 |
You might get faster response via email...then again you might have. Paul is a straight shooter plus he "knows" these trucks. Good luck!
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
12-17-2010, 10:26 AM | #13 |
Actually this is Mulk's thread I meant to link to:
http://67-72chevytrucks.com/vboard/s...d.php?t=403690
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-17-2010 at 10:27 AM. |
12-17-2010, 12:52 PM | #14 |
So to go with drop spindles and disk brakes what do you do about the master cylinder? I have power drum brakes on my 68 C20.
12-17-2010, 01:05 PM | #15 |
probably swap the proportion valve and master. booster should be same.
12-17-2010, 01:08 PM | #16 |
i am having a hard time finding rubber the sizes i want in 16" do stoctons 8 lug 15" wheels clear 3/4 brakes? i like a 29-30" out back with 26.6-27" up front.
12-17-2010, 03:24 PM | #17 |
Have you looked at Wheel Vintiques?
(maybe 17's) I thought Stockton Wheel had terrible reviews and customer service?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-17-2010 at 03:26 PM. |
12-17-2010, 03:40 PM | #18 |
yes, wheel vintique's wont work with oe hubcaps. i may run 15s with bfg silvertown 285 70 15s out back and some 235s up front. big white walls. dont know how that will look on white steelies. did argent silver ever make it on the truck rims back then?
12-17-2010, 03:42 PM | #19 |
In speaking with RenoKeene, he mentioned going with 3/4 ton suspension. I already have the disc conversion from 73-87 C/10 up front - well, let me back up. I have a C/10 with the 6BT (Cummins 5.9), and I want to go just a hair lower...I like the look of the 4"/6", and I still want to be able to use my truck to tow, carry, whatever....I still want it to behave like it should with hauling....just lower, faster and not exposing the oil pan to raccoons and squirrels...what do you suggest?
I thought about airbags, but I just want the truck lowered and road worthy, and if at all possible, something that I could put on one track or another...we'll see what that means.
Best Regards, Leon 1970 C/10 LWB Cummins Turbo - Build in Progress Many other toys as well... |
12-17-2010, 03:44 PM | #20 |
PS - I like what RenoKeene suggested, I actually want to know if anyone knows if the C/20 suspension parts will lower the truck or make it stay where it is with the motor being what it is (1,100 lbs)
12-17-2010, 03:44 PM | #21 |
I thought Wheel Vintiques was making oem wheels.
I know they have them in 5x5 now.
12-17-2010, 03:47 PM | #22 |
heres the truck. came from texas, 38000 mi. the gentleman passed away in 84 and it sat in a garage till a year ago. its original paint. white steelies with wide whites and stock hubcaps to much? i want it to set like the orange one.
12-17-2010, 03:48 PM | #23 |
the 8 lug wheels only fit baby moons. 11+" dia caps.
12-17-2010, 04:15 PM | #24 | |
That would look very nice
12-18-2010, 01:43 AM | #25 |
Nice looking burb!
