![]() Join Date: Apr 2008
License to Restore
I decided to put this in the projects section because all the work that went into it was enough to be labeled a project on it's own.
Last year at the big three swap meet (which is the size of the stadium parking lot) I bought a set of black and yellow plates for $50 that needed to be restored. The good sets that were not smashed but needed to be repainted were $200, the set that was already restored was $400. So I elected to try the restoration myself and bought the $50 ones. Went to the DMV and made sure they were clear and registered them in my name. The rear plate was in good condition but the front one was pretty smashed where it looks like the truck was in and accident, and half the numbers were flat. I decided to make a mold of the good plate so I could fix the wrinkled one. To make more sense of it I made a mold out of plaster of Paris with a perforated steel screen in the middle to take the strain of the reforming process. After I made a mold of both front and back of the good plate I dried it in my powder coat oven at 200* for a couple of hours to really cure it. Once cured I sand blasted the damaged plate with low pressure and 80 grit. Put it in the press and applied 40 tons of squeeze to it. I am happy with the results, there are a few imperfections in the steel but I think it came out great. The molds survived much better than I thought a few chips off the edges but I think I could use them again if I needed to. I am going to powder coat the black and Frazee the yellow. The original plate with all it's wrinkles. ![]() The molding process, front then back get molded. ![]() Screen to keep it all intact. ![]() Front done and drying. ![]() Came out great, on to the back side now. ![]() Both complete now to the press. ![]() Sand blasted the plate then squeezed it at around 40 ton ![]() Worked like a charm and the mold survived well enough to where I could use it again if needed. ![]() Powder coated the black and used Frazee oil based color "winch" lightened one shade and it is spot on. I touched up the four on the back plate after this photo and I have a hard time telling where it is. I conditioned the paint with penetrol to help it flow right so it would look more like the original. ![]()
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 Last edited by Mike Bradbury; 12-17-2010 at 04:36 AM. |
Re: License to Restore
Mike, Thats fantastic. Incredible job there. Bringing hope to abused license plates.
![]() Posted via Mobile Device
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
WOW! Thats great. I never would have thought Plaster of Paris would have held up to that. Great job.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
You know I was pretty surprised also, I was hoping that the screen would just hold it all in place as the pressure crushed the mold. I had no idea that it would hold up so well. These molds are only good to reform not to make new.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
67cheby
![]() Join Date: Sep 2008
good job and brilliant idea !!
Under Construction
Very nicely done!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Makes all the hassle with the DMV worth while;
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 Last edited by Mike Bradbury; 02-15-2011 at 02:50 AM. |
I had not realized how much the painted grill would make a difference. I have been very specific in the color choices for the truck and one of the big reasons for switching to the black California plates was because they matched the color scheme better. I know weird but the old plates were blue and yellow and did not look to good on a green truck.
I was going through this old thread and noticed that the last picture of the truck was before I painted the grill. Now it really ties the license plate in with the rest of the truck. ![]()
