Old 12-21-2010, 07:16 PM   #1
kuwait
kuwait's Avatar
Please help I'm from Kuwait
Hello
87 blazer k-5
454 big block model 1990
Manual model 1997
4wd
clutch model 1986
Trembling works if the car moved ????
What models of clutch that is not working Trembling ????
kuwait is offline   Reply With Quote
Old 12-21-2010, 08:42 PM   #2
chevyman95
chevyman95's Avatar
Re: Please help I'm from Kuwait
Sorry don't understand the question
chevyman95 is offline   Reply With Quote
Old 12-21-2010, 08:55 PM   #3
kuwait
kuwait's Avatar
Trembling when you move
Old 12-21-2010, 09:16 PM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
as in "shaking"?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-21-2010, 09:17 PM   #5
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
could be some oil residue on the clutch, or maybe the clutch isnt letting all the way out when you release the pedal.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 12-21-2010, 09:19 PM   #6
kuwait
kuwait's Avatar
Originally Posted by 68GMCCustom View Post
as in "shaking"?
Yes
Old 12-21-2010, 09:26 PM   #7
kuwait
kuwait's Avatar
New clutch model 1986 GM and there is no oil
5-speed
Old 12-21-2010, 09:30 PM   #8
Walts_restoration
so i assume you have a 454 big block chevy mated to a nv4500 or nv3500 from a newer chevy correct? Did you use the bellhousing from the 97? are you using mechanical or a hydro clutch?
Old 12-21-2010, 09:43 PM   #9
kuwait
kuwait's Avatar
yes
Old 12-21-2010, 09:51 PM   #10
kuwait
kuwait's Avatar
Trembled when you move possible model is different ??
Old 12-21-2010, 09:54 PM   #11
kuwait
kuwait's Avatar
I'm sorry in a few words I do not understand
Please help
Old 12-21-2010, 10:00 PM   #12
Sillyoldman
#16876
Sillyoldman's Avatar
Look at the easy stuff first. Check your U-joints motor mounts. Next thing I'd do is check the throw out bearing.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 12-21-2010, 10:13 PM   #13
kuwait
kuwait's Avatar
I'm going to try things easy if you do not benefit will change my clutch to a new model
Old 12-21-2010, 11:24 PM   #14
68GMCCustom
considering I don't think a 454 came in a 87 K5.....is the transmission mount the same as it always was?
Kurt -
Old 12-21-2010, 11:35 PM   #15
kuwait
kuwait's Avatar
I changed the motor and the transmission
Old 12-21-2010, 11:56 PM   #16
68GMCCustom
and how is the transmission supported?
Kurt -
Old 12-22-2010, 01:40 AM   #17
kuwait
kuwait's Avatar
I changed the open Transmission
Old 12-22-2010, 03:54 PM   #18
68GMCCustom
Not sure I follow you...does the transmission have a crossmember thats its bolted to thats supporting its weight?
Or... is the transmission just bolted to the bell housing and just hanging there?
Kurt -
Old 12-22-2010, 06:05 PM   #19
kuwait
kuwait's Avatar
No problems that I mentioned
Everything is okay only Trembling is a problem in the first start of the road
Old 12-22-2010, 06:48 PM   #20
Mkcustums
Mkcustums's Avatar
I think he is just getting severe clutch chatter or has a broken or loose mount somewhere. Only other thing I could imagine would be axle wrap, but it's kinda hard to say....
Kuwait - Do you know someone that could write us and explain it a little better? There is a bit of translation issues happening.
If it's your cluch it could be this. ↓↓↓↓ Thought it would be easier to just post this for you. (meaning I copied the info below off a site)
Troubleshooting-
Question: What causes clutch chatter?
Abswer: A high coefficient of friction, bad motor mounts, an incorrectly machined flywheel or faulty pressure plate, spring-centered race disc (aggravates chatter), and contamination (oil, grease, or rust).
Chatter is basically the engine winding up in the mounts as the clutch is engaging and then bouncing off the mounts, disengaging the clutch for a brief moment before engaging again and winding up again. No matter how aggressive a clutch is that would normally chatter severely on a normal street car, it generally won't chatter at all on a car with solid mounts and a rigid disc because there is no wind-up effect.
Mkcustums is offline   Reply With Quote
Old 12-22-2010, 07:45 PM   #21
kuwait
kuwait's Avatar
Thumbs up Re: Please help I'm from Kuwait
Troubleshooting-
Thanks for the explanation
