Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 08-24-2009, 09:39 PM   #1
SCOTI
SCOTI's Avatar
67-72 OE Shock Relocators
Lot's of times when guys drop their 67-72 coil spring trucks they opt for relocating the mounting points of the shocks to gain precious travel back. Since you must remove the original shock brackets, with just a little effort, drill, angle grinder w/a cutting/grinding disc, & a press or vise, you can modify your originals.
Uppers first: You want to relocate the hole higher & slightly over vs. OE....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is offline
Old 08-24-2009, 09:43 PM   #2
SCOTI
SCOTI's Avatar
Re: OE Shock Relocators
Mark the bracket vertically @ the C/L of the OE hole using a square. Scribe a horizontal line again 1.5" higher vs. the C/L of the OE hole. Scribe another line .750" over on the new horizontal line.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is offline
Old 08-24-2009, 09:50 PM   #3
SCOTI
SCOTI's Avatar
Drill the 'new' higher shock bolt hole. I prefer a drill press to keep things square. Since many guys don't have one, I did these w/a typical 1/2" hand drill.
I drill a smaller pilot hole on each side. Then drill thru one side w/a .500" bit & use the pilot hole on the opposite side to help keep the drill bit as square as possible. Deburr the edges when done.
Then, I made a template of the outside circumference of the shock bushing. I used that to dictate where I needed to trim off the excess material that will hit the shock body @ the now higher mounting location. Once I have the 'corner' marked. I use a larger diameter washer to scribe a hard line for where to cut.
Cut the extra material off & finish grind the bracket. These took about 1hr to do both brackets.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is offline
Old 08-24-2009, 09:56 PM   #4
SCOTI
SCOTI's Avatar
Lowers next: The lowers can be tweaked using a torch & BFH, a BF-vise, or a press. The press is the quickest & time was a factor for me so it's what I used for this set.
Remove the brackets from their original locations. You'll flip the drivers upside down & over to the pass side; the pass to the drivers. When you do this, there's about a 5/16" lip that will prevent the bracket from sitting flush.
I install the flipped bracket & mark the area the lip will contact w/a Sharpie. The lip beyond this point will need to be flattened by your method of choice.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is offline
Old 08-24-2009, 10:02 PM   #5
SCOTI
SCOTI's Avatar
I just keep pressing the lip flat a little @ a time until it's just that..... FLAT! Once your done, they simply bolt back up. If you don't flatten them far enough, you can grind a little off the truck arm for clearance but don't take off too much.
I do not recommend cutting the lip off. I feel it can cause a stress crack that could potentially shear @ some point should your shock ever bottom out (which lowered trucks do occassionally).
The rears took about 20mins start to finish on the press. A little longer if you add in the time spent marking them for the correct areas to clearance.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is offline
Old 08-24-2009, 10:03 PM   #6
SCOTI
SCOTI's Avatar
Net gain?
3" of shock travel for about 1-1.5hrs of effort. Cost... zero.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is offline
Closed Thread
