01-02-2011, 11:16 AM | #1 |
Hatch pic needed
Started the rebuild of my hatch and I am in need of a pic of the handle area (outside) without the handle in if anyone has one. I started with two hatches that are both a basket case. Will try to post up some pics on repairs so far, we'll see what I end up with.
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
01-02-2011, 10:54 PM | #2 |
Cochino_Racing_909
Re: Hatch pic needed
cool keep the pics coming.
01-05-2011, 03:36 PM | #3 |
These are the only ones I have of mine. Not sure if they help or not.
http://s282.photobucket.com/albums/k.../Blazer/hatch/
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
01-05-2011, 04:20 PM | #4 |
BobbyK from this forum did a hatch restoration and posted all the pics on this site back in jan 05. i found it by googling "repainting blazer top" down about midway he has a link called "HERE" if you click it he has all the pics i think you will need. it saved me when all my hardware was in a box and i had no idea what to do.
good luck |
01-05-2011, 04:23 PM | #5 |
heres the link, never done this before, hope it works.
http://67-72chevytrucks.com/vboard/s...d.php?t=146442 |
01-06-2011, 08:54 AM | #6 |
Thanks, already had it book marked, lots of useful info. Just trying to find one a little more detailed.
01-06-2011, 09:39 PM | #7 |
Tot Roddin'
Nice work!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-10-2011, 12:24 PM | #8 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
While was redoing the top.
Unfinished area you are asking for. Mine was broken around the handle as well. Here is a link to ALL the pic's I took while redoing my top. http://public.fotki.com/blazbk/blaze...nting_factory/ .
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
01-10-2011, 12:25 PM | #9 |
Here is a large but better pic of that area.
01-11-2011, 09:07 AM | #10 |
Thanks Bobby I have your top rebuild book marked, must have over looked the last pic. Thats the one I needed. Worked on that area this weekend and I think I may have matched the profile close enough. Will post pics later, thanks again.
01-14-2011, 01:00 PM | #11 |
Thought I would post a couple of recent pic of the hatch repairs, the first is the handle location. I took a piece of 16ga and ground a profile that match the lower profile and used it to help reproduce the profile around handle location. I built the area up on the back with fiberglass and finished the front with a thin layer of body filler. The second was the area around hinge location, it was completly gone. On the back side of the face there are two buttons built up for the screw area for the metal hinge covers so I could measure the correct distance for seperation off of my good side. Built that area up, cut the rectangular holes and finished with body filler.
01-14-2011, 02:10 PM | #12 |
GEARHEAD
Well done.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
01-16-2011, 11:32 PM | #13 |
how do we get new pins for the hinges?
01-17-2011, 01:36 AM | #14 |
GEARHEAD
I would try to find door hinge pins that have the same diameter. Most parts stores carry them, so just bring in one for comparison. If the exact size isn't found, get the next diameter bigger with the proper length and bore the holes out to fit.
01-17-2011, 08:23 PM | #15 |
In a previous thread I was told that the pins that some of the board vendors sell for doors are the same as the hatch pins, they just have to be shortened a little. I have to do that also, will post the results later.
01-24-2011, 11:37 PM | #16 |
Some more repair pics, before, during, and after drivers side hinge area. Will cut hinge notch in after installing metal plate and outside face.
01-29-2011, 06:57 PM | #17 |
nice
01-30-2011, 12:56 PM | #18 |
A couple more shots of the passenger side inner and donor piece, and finished piece.
01-30-2011, 04:32 PM | #19 |
GEARHEAD
Looking good. I have a couple that need a little work also, but not quite this much.
01-30-2011, 08:26 PM | #20 |
It gets worse but its all I had to work with. The glass is drying on this piece as I post, will post pics later.
02-02-2011, 09:24 AM | #21 |
Last repair of all of the missing parts, time to clean up and flip to do outside part of the inner and fit hardware.
02-02-2011, 10:12 AM | #22 |
GEARHEAD
Nice. I need good photos of the handle hardware going in. Mine was a chunk of iron oxide and not sure how it's supposed to go in.
02-02-2011, 11:03 PM | #23 |
72 K/5 Junkie
Nice detail, Thanks for sharing your hard work.
02-15-2011, 09:18 AM | #24 |
I have most of the hardware in place but don't have any pics yet, will post some in a day or two
02-16-2011, 09:01 PM | #25 |
Maybe this will help a little:
