Old 01-03-2011, 02:20 AM   #1
Bigblueburban
Bigblueburban's Avatar
Pickup door on suburban?
Does anyone know if a 71 pickup door will fit on my 72 burb? I've got some serious rust on the lower panel and instead of buying the patch from lmc I figured why not just buy a new door? Any avdice would be great
Bigblueburban is offline   Reply With Quote
Old 01-03-2011, 02:36 AM   #2
jmedero
jmedero's Avatar
Re: Pickup door on suburban?
I am not sure but I have a buddy that has some doors off of a rust free burb. Let mr know if your interested. I'll hook you two together.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 01-03-2011, 03:10 AM   #3
Bigblueburban
Ya deff interested it's really just my driver door. The guy on CL had a door for like 40$ but who knows what condition. Rust free is the way to be!
Old 01-03-2011, 05:23 AM   #4
67chevy1series
67chevy1series's Avatar
ithas been done but you will need to cut out a portion and replace with a suburban peice and replace window to
67chevy1series is offline   Reply With Quote
Old 01-03-2011, 11:49 AM   #5
Scott Johnson
Junior Member
Scott Johnson's Avatar
The window frame on the burb is squared at the top back portion and the pick-up door is rounded in that area. So like 67chevy1series said, you will have to replace the frame in that area with the burb part and use a burb window.
71 C10 Step Daily Driver
72 K10 Suburban Work in Progress
www.louisianaclassictruckclub.com
Scott Johnson is offline   Reply With Quote
Old 01-03-2011, 04:37 PM   #6
Bigblueburban
So basically if I already had the doors it would be worth it. I might as well just try and find some suburban doors. I knew there was no way it was gonna be as easy and just switching them over. And so the search contiues....
Old 01-04-2011, 12:43 AM   #7
71gmcburb
71gmcburb's Avatar
brothers sells replacement door shells
a wise man once said "There are only two real rules to life...
1 - Don't sweat the small stuff
2 - Everything is small stuff
71gmcburb is offline   Reply With Quote
Old 01-04-2011, 01:26 AM   #8
Bigblueburban
Ya I just checked it. Whole shell 305.99$ on sale and the outer door shell is 109.99. I'm 20 with a good job but not that good. Lol nice link to the site though thanks.
Old 01-04-2011, 02:04 AM   #9
71gmcburb
71gmcburb's Avatar
whats wrong with the set on the burb? you can use the truck set for patch panels or if your good at welding you can also cut the upper track off the doors and swap them
Old 01-04-2011, 10:27 PM   #10
jmedero
jmedero's Avatar
Pm Gary+rob on this forum and he has some nice doors. I have a buddy from Lakeland headed up here on saturday and he might can pick them up for you for a little gas $$.
Old 04-25-2011, 05:19 PM   #11
mlevario99
Bigblueburban, were you able to find the burb doors, or did you modify the truck door to fit the burb. I have the same dilema, and I found a set of truck doors in really good conditions.
mlevario99 is offline   Reply With Quote
