Old 01-03-2011, 01:00 PM   #1
78chevypickup
78 chevy 4x4 3/4 ton engine swap
Hi, I have a 78 chevy 4x4 3/4 ton pickup and I am putting a 2002 chevy 5.3 engine and 4l60E transmission in it. I was wondering what you guys think would be the best transfercase for my application. thanks a lot!
78chevypickup is offline   Reply With Quote
Old 01-03-2011, 03:55 PM   #2
78chevypickup
Re: 78 chevy 4x4 3/4 ton engine swap
I had a 203 transfercase in the pickup but with the new (4l60e) transmission I need a diff. transfercase please help thanks!
Old 01-03-2011, 04:44 PM   #3
benoit454
Chris
benoit454's Avatar
do you want to keep a full time case or does it have a part time kit in it? You may need to find an adapter that will let you bolt it up to the 4l60, maybe advance adapters. I aint a hundred percent but I think they have the same tail bolts and pattern as a 700r4? if so then it's the same as a th350 and all you need is a th350 or 700r4 t-case adapter which came stock in these trucks so should be easy to find. I'm not completely sure of the tail though so might need to research more, if not then advance adapters should have what you need. I thinkmost 4x4 that had the 4l60 is a DS drop like the 88-98 trucks so it would be on the wrong side for your front axle. That may not be a problem if you wanted one of the newer like 241c t-cases but you'd need a new front axle like a ford one or something with a ds pumpkin/diff. That could lead into alot of things, like steering, brakes, etc, that would need modified or changed.
If the th350 or 700r4 adapter would work on your trans you could use a 208 t-case or even hunt down a 205, maybe find the 88-91 burb 241 that has a ps drop.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 01-04-2011, 02:01 PM   #4
78chevypickup
Hey thanks a lot I'll check it out
Old 02-10-2011, 03:09 PM   #5
78chevypickup
Benoit454 thanks alot, advance adapters had the adapters i needed to put my old t-case on my 4l60e, thanks so much
Old 02-10-2011, 07:27 PM   #6
78chevypickup
Does anyone know how to tell a 203 t-case (is a 203 full time?) from a 205 t-case i think my 78 chevy pickup has a 205 but not for sure, it had a 400sbc 400trans. It has a spot for a PTO to be mounted, i know they put tags on transforcases but i can't find one. Thanks
Old 02-10-2011, 09:41 PM   #7
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Does your truck have unlockable front hubs?
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 02-10-2011, 10:13 PM   #8
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
The 205 has a small circular plate in back with 3 bolts on it. It is gear driven (not chain) and is the strongest T case in these trucks. Bulletproof.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 02-11-2011, 04:56 PM   #9
78chevypickup
the hubs are warn hubs and can be locked and unlocked, and i looked at the circular plate on the back and it has more than 3 bolts so i guess its a 203?
Old 02-12-2011, 03:26 PM   #10
78chevypickup
Does anyone know where one can find custom motor mounts for 78 chevy to a chevy 5.3? thank you "the white elephant" your help was great!
Old 02-28-2011, 04:26 PM   #11
78chevypickup
thanks a lot to all the guys who have been helping me on here, last week i got my 5.3 sit in my pickup and this week hopefuly i can get a the motor mounts put in. This is a project, but a fun one so worth it hope to have pictures up soon.
Old 03-22-2011, 07:53 PM   #12
78chevypickup
hey just woundering, if I would put long tube headers on my 5.3 does anyone know if that will help my mileage? just not to sure thanks!
Old 03-22-2011, 11:15 PM   #13
TheWhiteElephant
God is good!
As far as I know, not a noticeable amount.
Mando
Old 03-29-2011, 03:06 PM   #14
78chevypickup
thanks TheWhiteElephant your help is great i got one more ? for you. Do you know where i can find fuel pressure spec's. here the deal i have a 2002 5.3 enigne and i need a fuel pump for it and i think it needs 55-62psi and i found a 07 chevy pickup tank and pump do you think the pressure would be the same or not? thanks guys!
