01-06-2011, 01:27 AM | #1 |
69 or 70 grille
How do ya tell the difference between the 2?
01-06-2011, 01:29 AM | #2 |
Re: 69 or 70 grille
the outers are the same but the inners are different
69 has a silver painted eggcrate 70 when you look from a distance it looks as if it has nothches in the chrome on the eggcrate inner grille hope that makes sense |
01-06-2011, 01:33 AM | #3 |
Re: 69 or 70 grille
so, on my first pic the top is a 69? and the bottom a 70? or are they both the same?
01-06-2011, 01:42 AM | #4 |
67-72 parts collector,…
Re: 69 or 70 grille
They both look like '70 inner grilles,... to me.
01-06-2011, 01:46 AM | #5 |
Re: 69 or 70 grille
yes the top is 69 and bottom is 70 they are completely interchangable
01-06-2011, 01:54 AM | #6 | |
Re: 69 or 70 grille
It's just a faded version of the lower '70 grille.
01-06-2011, 01:55 AM | #7 |
Re: 69 or 70 grille
lolife99- how can you tell?
01-06-2011, 01:56 AM | #8 |
Re: 69 or 70 grille
not to steel his thunder but i thoght the same thing until i noticed it was just worn out
01-06-2011, 02:17 AM | #9 |
Re: 69 or 70 grille
Look at the lower grille.
The 4 highlighted (with silver paint) horizontal lines,... were what designated them as a '70 grille. The grille is actually raised in these areas. The '69 grilles were a solid "eggcrate pattern,... with out the raised areas. All the repop grilles are the 70 version. (That I have seen) I have an NOS grille that was ordered from my GM dealer in 1995. It was ordered for a '69. When I opened the box,... it was a '70 grill with the eggcrate area painted solid silver to replicate a '69 grille. I'll try to find you a picture of an original '69 inner grille.
01-06-2011, 02:26 AM | #10 |
Re: 69 or 70 grille
The only noticeable change for 1970 was a minor update to the Chevrolet grille. At first glance, the 1969 and 1970 grille appear identical. However, 1970's plastic inserts actually have highlights that break the appearance into 6 separate sections.
01-06-2011, 02:34 AM | #11 |
Re: 69 or 70 grille
so are 69-original-grilles hard to find?
01-06-2011, 02:43 AM | #12 |
Re: 69 or 70 grille
Yes.
I try to buy all the good '69 grilles I can afford. So far,... I have none.
01-06-2011, 02:44 AM | #13 |
Re: 69 or 70 grille
But I would be interested in buying the lower '70 grille,... (in the first picture),... if you want to sell it,... and if I can afford shipping.
(I have both a '69 and a '70 truck).
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-06-2011 at 02:45 AM. |
01-09-2011, 12:21 AM | #14 |
Re: 69 or 70 grille
is there a paint code for the "silver" area?
01-09-2011, 01:05 AM | #15 |
Re: 69 or 70 grille
If I remember right, I seen somewhere that the outers are different too, between the turnsignal and headlight opening. One makes a "loop" in the "rib" and the other runs to the headlight opening like the ones above.
Name: Les ---------------------- Couple 80s Couple 70s One 68 |
