Old 01-07-2011, 12:43 AM   #1
derekb
derekb's Avatar
should be easy answer
Where would I start? Headlights are on low beam but high beam indicator is on. Blinkers are not on but arrows on dash are lit up. Engage blinker, light flashes on/off. It sounds like something is crossed. Can someone direct me where to start? Thanks in advance!!
derekb is offline   Reply With Quote
Old 01-07-2011, 12:47 AM   #2
geezer#99
geezer#99's Avatar
Re: should be easy answer
Check turn signal flasher. Should be plugged into fuse box.
Old 01-07-2011, 12:50 AM   #3
78bronzechariot
78bronzechariot's Avatar
Check the ground connections to your dash and the quality of the printed circuit. I had an el camino that did the same thing when the ground broke in the printed circuit. It appeared that the ground from the dash was backfeeding through the lightbulbs.
78bronzechariot is offline   Reply With Quote
Old 01-07-2011, 12:59 AM   #4
VA72C10
VA72C10
VA72C10's Avatar
check all your grounds including in the rear tail lights and side markers...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-07-2011, 08:23 AM   #5
splehigh
splehigh's Avatar
I agree. Sounds like a grounding issue.
splehigh is offline   Reply With Quote
Old 01-08-2011, 01:21 AM   #6
derekb
derekb's Avatar
So I got home from work and hit the garage. Pulled guage cluster off and low and behold, I found something that can only be described with a picture. The previous owner had rigged so many wires that I am surprised it didn't catch on fire. Spent 2 hours rewiring, pulling wires, rerouting wires. No change in the issue but man do I feel good after cleaning that up. So one last question...is there supposed to be a seperate ground wire to the guage cluster or is it inclusive in the wire harness.
Old 01-08-2011, 04:18 AM   #7
matthew20061
69' Chevy Stepside
matthew20061's Avatar
That definitely sounds like a grounding issue my truck did the exact same thing with the blinker lights lit up when my tail lights weren't grounded very well I have no idea why but after I grounded them and my front turn signals it fixed the problem.
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 01-08-2011, 03:35 PM   #8
swamp rat
swamp rat's Avatar
I beleve its inclusive in the harness, but its been a number of years since i pulled my bezel out.
I had the high beam indicator come on when my lights were on low beam as well, my solution was that 2 of the wires were pulled from one of the headlight plugs and put back into the plug in the wrong location.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
