Old 01-09-2011, 07:39 PM   #1
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Using stock fuel pump
Here's my idea, The stock fuel pump was included for my engine and trans(07 4.8/4L80e). So I'm thinking about removing the pump from the bucket and adapting it to my blazer tank pickup, like Larry S did here.
http://67-72chevytrucks.com/vboard/s...tank+fuel+pump
My Idea is basically, cut off the end of the blazer pickup tube. Attach the pump's output to the tube using high pressure hose and support the pump in some way. I would need to use the vette filter/reg as I would be eliminating the internal filter/reg in the pump bucket.
So questions are;
1, Anyone done this? I tried PM'ing Larry S but he hasn't been on here in just about a year.
2, Can I run an internal pump without a bucket?
3, Any other thoughts?
Here is what I'd be working with.
And the filter/reg that will be eliminated
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-12-2011, 01:01 PM   #2
usmcchevy
usmcchevy's Avatar
Re: Using stock fuel pump
Nobody???
Build thread
LSx Swap FAQ index
Old 01-13-2011, 01:26 PM   #3
matthew20061
69' Chevy Stepside
matthew20061's Avatar
I tried using the stock one inside my rear mounted blazer gas tank and it worked pretty good. The only way it would fit was without the sending unit/float so that was the main reason I removed it put in the stock sending unit and used an external pump (Walbro 255 $100 on ebay). What gas tank are you using? If its not the blazer tank you might be able to fit that pump in there with the float.
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 01-13-2011, 08:39 PM   #4
usmcchevy
usmcchevy's Avatar
Thanks for the reply! I'm using a 67-72 Blazer tank. So you are running a Walbro 255 with a stock blazer pick up (no bucket)?
Build thread
LSx Swap FAQ index
Old 01-13-2011, 08:57 PM   #5
matthew20061
69' Chevy Stepside
Ya, I'm using the factory 67-72 blazer pick up that came with the new 67-72 blazer gas tank, and I have a hose running off of that to the external Walbro pump mounted on the cross member right in front of the tank. When I had the factory gm pump for ls motors mounted inside the tank there was no way to fit a fuel gauge sending unit in there along with the pump that I could figure out.
-Matthew
Old 01-13-2011, 10:01 PM   #6
usmcchevy
usmcchevy's Avatar
Awesome! Thanks, guess I'll just get a inline pump.
Build thread
LSx Swap FAQ index
Old 01-13-2011, 10:46 PM   #7
RocketKing
RocketKing's Avatar
We modified my LS pump (2004 Chevy) with an '85 sending unit. I call it FrankenPump.
I still have to hook the wires up and install the the fuel sender from my original gas tank but the biggest factor is I used a 2000 Wrangler tank with baffles so I can run without the bucket.
Rex
RocketKing is offline   Reply With Quote
Old 01-13-2011, 11:30 PM   #8
matthew20061
69' Chevy Stepside
That looks exactly like what I had done originally but it was just too screwy so I removed it lol!
-Matthew
Old 01-14-2011, 12:57 AM   #9
RocketKing
RocketKing's Avatar
Yep, that is why I called it FrankenPump. Scares me just to look at...
Rex
Old 01-14-2011, 02:09 AM   #10
matthew20061
69' Chevy Stepside
Hahaha ya.... mine was the exact same way!
-Matthew
Old 01-14-2011, 01:01 PM   #11
usmcchevy
usmcchevy's Avatar
Thanks for the pics RocketKing........but using a inline looks better and better
Build thread
LSx Swap FAQ index
Old 01-14-2011, 02:58 PM   #12
RocketKing
RocketKing's Avatar
I completely understand. I have also been looking at options for fuel pumps. I have not convinced myself I could sleep at night knowing that thing was in my fuel tank... just laying there... waiting.
Rex
