Old 01-09-2011, 11:43 PM   #1
72gmcshorty
72gmcshorty's Avatar
which tank should i get?
I have a 72 blazer. I need a new tank anyways. I want something thinner than the factory tank. I see the 73+ blazer tanks fit with a little modification. I am unsure about a 25 gal or 31 gal. Is there a specific year that will be baffled and have an in-tank pump that will give the correct PSI?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 01-10-2011, 11:30 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: which tank should i get?
You would need to look at the 87 to 91 blazer tanks for EFI pump, but IDK if it would supply the 58PSI for the motor or if you would need to change the pump out.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-10-2011, 11:14 PM   #3
72gmcshorty
Is there a pump that fits this tank and would give the proper PSI?
1992 Gmc 2wd
Old 01-11-2011, 07:41 PM   #4
OKGMC4
OKGMC4's Avatar
TBI pumps are made to run 9-13 psi. Tuned port injection requires the higher pressure you need. Sometimes a TPI pump can be made to fit in a TBI sender. Look at 85-92 camaro pumps. If you get into LT1 and LS1 applications they use a composite pump that is is a different design and less adaptable unless you want to do more modification to the tank.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 01-11-2011, 10:19 PM   #5
Mr. 250r
Mr. 250r's Avatar
i see alot of people using the tbi fuel tanks with a corvette pump ran just like the tbi because they didn't want to use external pumps ill look for more info about it
Mr. 250r is offline   Reply With Quote
Old 01-31-2011, 01:22 AM   #6
72gmcshorty
anyone else?
1992 Gmc 2wd
Old 01-31-2011, 02:45 AM   #7
OldCreek
OldCreek's Avatar
I used a 87+ tbi 25gallon tank in my 71 Blazer with 4" spring lift. It sits just behind/above the differential. I moved the rearmost cross member back to the end of the frame rails. The aftermarket tanks have a "baffle"...but it is just a really shallow reservoir. The OEM tanks have the full baffling...unless I just bought the wrong brand.
The fuel pump is another story. You'll have to get an intank fuel pump rated for the LSx motor. It should fit in the stock position/tank. I THINK I used an ACDELCO EP381 with a corvette regulator/filter WIX 33737.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
