01-16-2011, 02:49 PM | #1 |
Stepside: Longbed to shortbed...
I have a '71 longbed that I love, but I have to admit, IMOH it would look better as a shortbed. What exactly would be involved to do this? Could I take off the bed, remove the front panel, cut off a certain(how much?) amount off the front of the bed and then remove and box the frame(specific area?) the same amount, driveshaft same amount, fuel/brake-lines and have this accomplished? Or is it more complicated than that?
Thanks |
01-16-2011, 03:13 PM | #2 |
Re: Stepside: Longbed to shortbed...
Here I found this for yuh....http://www.sporttruck.com/techarticl...ion/index.html
01-16-2011, 03:24 PM | #3 |
If you look at side shots of a short bed C-10 stepside and your longbed C-10 you will see that there is/are a few inches extra behind the fenders that will need to be trimmed off to make things right in appearance.
Shortening the wheelbase and box to get it to the short bed length is the first step then shorten the back end of the box to make it into a shortbed box instead of a cut down longbed box with extra inches on the back end. A good spotweld cutter should let you cut the spot welds out of the corner posts so that you can move them and weld them back. Last edited by mr48chev; 01-16-2011 at 03:25 PM. |
01-16-2011, 03:28 PM | #4 | |
01-16-2011, 05:05 PM | #5 |
Got this from the FAQ section. Depending on the year you are working on the measurements may vary.
http://67-72chevytrucks.com/vboard/s...d.php?t=123624
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa Last edited by JDL; 01-16-2011 at 05:53 PM. |
01-16-2011, 05:40 PM | #6 | |
01-16-2011, 05:55 PM | #7 |
try it know
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
01-16-2011, 06:56 PM | #8 |
Still comes up: Not found...
01-16-2011, 07:00 PM | #9 |
Link works for me. airbrushguy, you can't click on the broken link that you quoted, just the link that JDL fixed.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
01-16-2011, 07:35 PM | #10 |
The Older Generation
Works for me too. LockDoc
01-16-2011, 08:09 PM | #11 |
Thanks guys...some of us are a little slower than others. Thanks
01-16-2011, 10:31 PM | #12 | |
Running on empty
_____________________________________________ Tim We have two rules here at the Rock. Rule #1: No writing on the walls. Rule#2: Obey all rules 70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi; 94 Bronco XLT 302, auto;worn out daily driver |
