01-18-2011, 01:08 PM | #1 |
Z'd frame?
Should i run into serious mods with 2.5 or 3inch z. I've heard that 4 inch creates many problems. Trying to lay out with 2.5 drop spindles bags and z'd frame. Will I have to cut trans/ driveshaft tunnel for any amount of Z I do?
Get Low |
01-18-2011, 11:23 PM | #2 |
Re: Z'd frame?
Search, search, search, man. Don't go anything past 3" you'll be in a lot of trouble then. Im not sure on the trans tunnel, maybe have to run a high hump trans pan from a 4x4?
01-19-2011, 10:42 AM | #3 |
Re: Z'd frame?
3" is the way to go or a dropped crossmember.
01-19-2011, 08:54 PM | #4 |
Re: Z'd frame?
by lay out what do you mean do you mean frame, pinch weld, or rocker
01-19-2011, 11:37 PM | #5 |
Re: Z'd frame?
you can lay the frame or pinch with a 3" Z. If you want to lay the pinchweld you will need to cut off about an inch and a half off the bottom of the frame right under the cab about where your feet are.
01-19-2011, 11:39 PM | #6 |
Happy to be here
Re: Z'd frame?
It would help if you told us what year truck, and SWB or LWB.
01-20-2011, 10:03 AM | #7 |
Re: Z'd frame?
1966 swb stepside. I would like to lay rockers.
Get Low |
01-20-2011, 10:36 AM | #8 |
One day...
Re: Z'd frame?
Mine with a 2.5 Z made in the new frame, illl look for a better pic..
Could have went lower but i left room for oops's and i didnt grind the truck to a nub before i got stopped. Last edited by scotts62; 01-20-2011 at 10:37 AM. |
01-20-2011, 11:10 AM | #9 |
Re: Z'd frame?
I guess a better question would be, If the frame is on the ground, how low is the body?
Get Low |
01-20-2011, 07:59 PM | #10 |
Re: Z'd frame?
A straight edge and a tape measure will tell you that
01-20-2011, 08:06 PM | #11 |
Re: Z'd frame?
time is money...i'd invest in drop member and let the cnc machine do the measuring...
John J Bodied 1994 Suburban on custom frame - http://67-72chevytrucks.com/vboard/s...d.php?t=672297 Dad's 1948 Suburban - http://67-72chevytrucks.com/vboard/s...d.php?t=563150 Bagged 1995 Suburban - SOLD Bodied 1995 Tahoe -SOLD |
01-20-2011, 08:46 PM | #12 |
low n' slo
Re: Z'd frame?
if you have the coin a drop member would be the better option.
but if not (like most of us), there is nothing wrong with a z if you do it right. 3" should lay the frame with your setup. just dont do like the guy that had a 6" z..lol
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
01-20-2011, 11:08 PM | #13 |
Happy to be here
Re: Z'd frame?
That is correct, "If you do it right". Most I have seen are not done right.
01-21-2011, 08:35 AM | #14 |
Re: Z'd frame?
3" Z and 1.5" off the bottom of the frame, the curved part under the cab and it will lay pinch weld. Thats pretty simple..
01-21-2011, 02:58 PM | #15 |
Re: Z'd frame?
I am going to stick with the 3in Z, and drop spindles and see how low that is before I start cutting any more frame away. Thanks for all the info from everyone.
Get Low |
