Building this C5 5 Window for my Wife
I started this project in November. I've had this cab for about 10 years and always thought I would build it just after I finished my 55 BelAir. Didn't realize it would be this long to get to it.
I started with a 98 C5 Vette and modified the frame rail width of the Vette to fit under the AD cab. ![]() ![]() http://pic60.picturetrail.com/VOL172.../394679247.jpg Mocking up for the bed ![]() Cell Phone pic, One bed Side tacked on ![]() I cut down a tailgate I had from a 67. I made the stake pockets similat to stack with just a little more detail ![]() ![]() ![]() The dash was pretty beat up so I tried my skills and made this one ![]() That's about it. The wheelbase is about 10'' shorter that a stock short bed AD . I'll be keeping the drivetrain mostly stock. Wife really dosen't want a HotRod. Just a "Cute" old truck. |
Certified Car Nut
Re: Building this C5 5 Window for my Wife
Its looking great.
Cool, Nice restomod!
Could you give more details on what you modified to make that tail gate work?
What latchs and straps are you using. Looks good on there! |
This is a really cool build.
Kim |
#7 | |
I also plan on using the vette gas strut for the gate if it works out Last edited by Tuned55; 01-19-2011 at 11:36 PM. |
![]() Join Date: Jul 2010
nice
Looking good, but wasn't it tempting to just play with the 'vette? :-) Or was it hot. haha.
#10 | |
It seems I have a lot done on the build since last posting.
Bed is done with the exception of some final welding, grinding and floor ![]() Gas door is mounted and plumbed to tank ![]() http://pic60.picturetrail.com/VOL172.../395023766.jpg ![]() ![]() I came up with this to hold the tail gate in open posistion. Stainless steel rods retract into a nylon bushing ![]() Here's a shot of the spring loaded gate latch I made ![]() |
I got the seat base made and seats in also
#13 |
Very nice build. Do you have any picture of how you built your spring loaded gate latch?
FAT MIKE My 59 http://67-72chevytrucks.com/vboard/s...d.php?t=400201 My 47 http://67-72chevytrucks.com/vboard/s...d.php?t=386848 |
#14 |
Wow. Looks great. Aside from widening the frame, did you have to do anything else to it?
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
#15 |
subscribed.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
#16 |
Looking real nice.
Kim |
#17 |
You know I didn't take any pics as I was making it. This is how I made it. I used a piece of SS tube and milled out a J type slot about 1'' from the end. I welded a plug on the end. I then made a rod on the lathe to slid inside that with a smaller dia. to fit inside the spring. Just down from that I tapped a hole and threaded in a a small handle. So, spring goes in first then plunger, than the handle gets screwed. Tack weld it in the gate. Used some persian blue on the end of plunger to mark where to drill the hole in bed side. That's about it. An evening project.
#18 |
VA72C10
![]() Join Date: Mar 2008
very nice work....love all the details and it should be a super nice drive!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#19 |
Certified Car Nut
You the man tuned55, another great build. Great work.
#20 |
i'll be watching this one.details and pictures!!!!!!!!!!!!!!!!
#21 |
![]() Join Date: May 2005
That's cool man!!!!!!!!!!!!!!!!
#22 |
I actually narrowed the width of the frame about 10'' each side. The wheelbase remains stock C5 just over 10'' shorter than an AD short bed. As far as anything else I had to add to the lenght in the rear and shorten the front. The usual stuff like core support. cab and bed mounts. The next one will go much faster
#23 |
Thanks for all your kind words and interest!
#24 |
there's always a reason for interest. could it be what your doing is appreciated?
#25 |
![]() Join Date: Apr 2005
Sweet build!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
