01-20-2011, 08:45 PM | #1 |
Parts for my 72
Ok, so I'm pretty new here and never posted before. I may be in the wrong place so somebody help me out please?!
I've got a 72 3/4 ton 4x4 that's fully restored. It's a 350/4 speed combo and I've got it in the shop putting a new clutch in it. In the process, found that the cast support between the transmission and transfer case has been broken. It wouldn't be such a problem but it's been brazed before and developed a crack just beside it and another further away. Is there any company that may reproduce this? I'm striking out at all the local salvage yards. I've checked LMC, Brothers, Classic Industries, and Classic Parts with no luck. I've been told that it's a '70-'72 specific piece but a 1/2 ton may work for a 3/4 ton as long as it's a manual. ANY HELP WOULD BE GREATLY APPRECIATED!!!!
94 GMC Sierra GT with 66k original miles,'41 Chevy SOLD, '68 Chevy 1/2 2wd-2nd owner SOLD, '72 Chevy 3/4 4wd SOLD, '08 Chevy 1/2 4wd-service pickup, 2005 GMC 1/2 4wd 4 door lifted-my toy-SOLD, 2007 GMC Yukon XL Denali, 2009 Harley Street Glide Last edited by dingesb; 01-20-2011 at 08:57 PM. |
01-22-2011, 03:49 PM | #2 |
Re: Parts for my 72
If nothing else does someone have a book with a part number I could use? I don't have a whole lot of literature on my '72, mainly just my '68 1/2 ton 2wd. Thanks!!
94 GMC Sierra GT with 66k original miles,'41 Chevy SOLD, '68 Chevy 1/2 2wd-2nd owner SOLD, '72 Chevy 3/4 4wd SOLD, '08 Chevy 1/2 4wd-service pickup, 2005 GMC 1/2 4wd 4 door lifted-my toy-SOLD, 2007 GMC Yukon XL Denali, 2009 Harley Street Glide |
01-23-2011, 02:18 AM | #3 |
Re: Parts for my 72
Check out the parts for sale board and PM the people that are parting out the trucks and ask them.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
01-23-2011, 10:22 AM | #4 |
Born Psycho
Re: Parts for my 72
any chevy/gmc with the 465/205 combo will work. 70-80s-not sure exact year GM stopped using this combo.if no-one here can help try calling (510)651-5874 and talk with Bill.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
01-23-2011, 10:43 AM | #5 |
Re: Parts for my 72
Thanks a bunch guys!!
01-23-2011, 01:08 PM | #6 |
Re: Parts for my 72
I found this for sale in the classifieds section. I assume that this is the same as what I have.
http://67-72chevytrucks.com/vboard/s...ight=465%2F205 Looking on google gave me this for sale on Ebay. It seems that this would be the correct adaptor for my particular situation. http://cgi.ebay.com/ebaymotors/chevy...Q5fAccessories This would be so much easier if my '72 wasn't 150+ miles away from me!! Thanks!
01-23-2011, 01:11 PM | #7 |
Re: Parts for my 72
Better not to assume anything, You need to know what model transmossion and transfer case you have.
01-23-2011, 01:40 PM | #8 |
Re: Parts for my 72
I agree completely...the old saying about "don't assume....it makes an ass..." seems to ring true every time! I called my dad and asked him about the '72 and it's still got the factory running gear in it that was in it new. I won't be able to get ahold of my local mechanic back home working on it until tomorrow so I suppose I should hold off on ordering anything, huh?
01-23-2011, 04:24 PM | #9 |
Re: Parts for my 72
The piece you are talking about is called a transmission to transfercase adapter. As recently as 5 or so years ago I was able to purchase the adapter for my truck right over the counter at my local Chevy dealer. However my adapter was for the NP205 to th350. All the adapters are different and are specific to the combo.
My father-in-law has an 85 or so 3/4 ton pickup. I'm not sure what specific 4-speed transmission he has but it for sure has a NP205 so you MIGHT be in luck buying new. I don't admire the job you have in front of you. Those are some heavy pieces you are talking about. On my adapter there are oil seals on each end that the coupler rides around on. They keep the tranny fluid in the th350 and the gear oil in the transfer case. Because I didn't want to go back I got a new coupler too. I'm not sure on the 4-speeds but you may want to investigate and consider that too. One more thing as long as I'm data dumping on 1972 transfer case adapters... GM made all transmission/transfercase combos in 1972 the same length by having different lengths of adapters. Long story short, if you want to ditch the 4-speed for a th350, you can make the swap without any other changes. The driveshafts on all 1972s are the same length and all use the same crossmember under there. HOWEVER to do the swap you need to get a complete combo. For some reason the manual transmissions had 10-spline output shafts and therefore the NP205 has 10 splines on its input shaft. The th350 has 28 splines on its output shaft and needs to be coupled to an input shaft with 28 splines.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Tags |
3/4 ton, 4x4, parts |
