Old 01-22-2011, 06:27 PM   #1
sleepertruck72
sleepertruck72's Avatar
Talking Vortec Serpentine Belt swap ?'s
So I finally got the set up for my serpentine set up. I have the 350 HO crate engine with vortec heads. GM Performance says to use the L31 RPO accessories from 96-98 Chevy trucks. I scored a complete set up and I was wondering if anyone has the same set-up. It looks like the p/s fittings are metric and will need to be changed, and I am hoping the a/c compressor does not interfere with the master cylinder. The alternator should not be a problem other than run the wire to the passenger side. I got a wiring diagram that shows it just uses one wire. The water pump has two nipples for the heater hoses. It looks like they are press fit. I will have to plug one with a hose/clamp ? Any input would be appreciated. I need to find my camera so I can post pics.
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 01-22-2011, 09:07 PM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: Vortec Serpentine Belt swap ?'s
I have used the serpentine set up from TBI trucks because the A/C compressor is on the correct side for 72 trucks (pass). I have a Vortec setup off a take out engine, but haven't used it on a 67-72 due to this issue. Also, the A/C compressors and alternators are ALOT more expensive on the Vortec.
AS for the PS fitting, you should be able to remove the fitting out of the rear of the Vortec pump and replace it with the one out of your 72 pump.
WIDESIDE72 is offline   Reply With Quote
Old 01-22-2011, 10:28 PM   #3
sleepertruck72
Wideside72,
That makes sense for the a./c compressor to be on the passsenger side. I should of thought about it before, but I was going off what GM Performance published in the manual with the crate engine. Oh well I got it all fairly priced, hopefully it lasts for a while. I mainly just wanted to get rid of the v-belts because I have had to adjust a tad too many times to stop squealing. The lower alternator bracket is missing that pressed in spacer to keep it aligned. I dont have A/C anyway but the compressor is a junk one that will have a block off plate for the hoses. I replaced it for a friend and kept the old one. I will swap that over to an A/C delete eventually. I will try the fitting on the p/s pump. Thanks for the input ! I will try to post pics, I must find my camera
72 C20 Longbed
05 1500 Z71
Old 01-22-2011, 11:18 PM   #4
cparman
sharp as a marble
here is my 330 hp crate in my Blazer
cparman is offline   Reply With Quote
Old 01-23-2011, 01:41 AM   #5
sleepertruck72
cparman,
Nice looking engine compartment !!! Is that the T.B.I. serpentine set-up as mentioned by wideside72? It does look nice and the alternator stays on the driver side. Did you get the 350HO with the serpentine set up or did you add it afterwards ? I think I am ready to start swapping mine tomorrow, Thanks for the pic
72 C20 Longbed
05 1500 Z71
Old 01-23-2011, 01:43 AM   #6
67chevy1series
67chevy1series's Avatar
so hows it goin jorge i will probably be able to get the stuff if your ready at maybe 6:30 or 7 tommorow
67chevy1series is offline   Reply With Quote
Old 01-23-2011, 01:46 AM   #7
sleepertruck72
Ricky,
I didnt get a chance to start today. Alot of stuff came up as usual I am hoping to start tomorrow, but the thing is it's my daily driver so I must finish the same day so I can keep driving to work I'll keep you posted
72 C20 Longbed
05 1500 Z71
Old 01-23-2011, 01:50 AM   #8
67chevy1series
sounds good on friday i was gonna go to that junk yard on daubenberger road and get some parts i stashed there and was gonna put some $ in bank so i could buy somthin and ship somthin and find a shippin qoute as you can tell with the word WAS none of that was accomplished this weekend has been hectic i understand jorge!
Old 01-23-2011, 01:53 AM   #9
sleepertruck72
Here is a pic of the water pump I am talking about. I will only need the nipple on the right for my heater core, the other one will not be needed. Is there another method of plugging this other than a cheesy hose with a clamp. I believe these nipples are pressed in ?
72 C20 Longbed
05 1500 Z71
Old 01-23-2011, 01:56 AM   #10
sleepertruck72
Did you stash it in a 68 suburban they have there by any chance ? I think I found your stuff
72 C20 Longbed
05 1500 Z71
Old 01-23-2011, 02:13 AM   #11
67chevy1series
they have a burb! i hid my stuff under a panel
Old 01-23-2011, 02:40 AM   #12
sleepertruck72
They had a burb, it got stripped really quick! The panel you are talking about has about a million window regulators and vent windows in it ? Go back and get your stuff before I find it
72 C20 Longbed
05 1500 Z71
Old 01-23-2011, 02:48 AM   #13
67chevy1series
hahah ya that panel is the one! i am going monday it is just an air cleaner for a 67
Old 01-23-2011, 12:06 PM   #14
Lee H
Lee H's Avatar
Nice looking set up. What did you use for upper and lower radiator hoses, part numbers??
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 01-23-2011, 12:58 PM   #15
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
im running a serp setup from 88-92 camaro/firebird with V8. its the EXACT same as the overpriced GMPP one. it can be had for 125 with all accessories. they show up all the time on thirdgen.org in the classified section
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 01-23-2011, 02:06 PM   #16
peglegs
peglegs's Avatar
vasquezmrysvll, what year is your engine ? and what truck did you put it in? ty
1990 chevy 4x4 with a 1940 IHC body
peglegs is offline   Reply With Quote
Old 01-23-2011, 02:44 PM   #17
vasquezmrysvll
"the other guy"
the block is 99 gmpp 350 and the heads are 98 062 vortec in my 67 c10. the serp setup will fit any sbc with acc. holes in the heads
Old 01-23-2011, 03:56 PM   #18
cparman
sharp as a marble
When I Bought my blazer, EVERYTHING on the front of the motor was tired. One thing led to another - - - water pump started leaking, bolt broke off in the block, had been drilled before, and was not centered etc.
I bought the GM serp belt setup separate from the crate engine. The serp belt set is a clean way to go for all of us. Took a bit of work to get the lower rad hose to fit the way I wanted it to, and I swapped the P/S pressure hose fitting from the old pump to the new, and every thing else was a bolt on. I powder coated all of the pulleys before the install.
cparman,
