Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 01-22-2011, 08:09 PM   #1
Cbrown67
Guys I need help with dual voice coils
Guys I need to know how to wire my 2 L7 dual voice Kicker subs I have a 4ohm. the amp is a kenwood 1800 watt amp model number KAC-9104D.
I need to know if these need to be in series or parallel the box are both single sealed boxes.
Cbrown67 is offline   Reply With Quote
Old 01-22-2011, 09:55 PM   #2
jimmydean
jimmydean's Avatar
Re: Guys I need help with dual voice coils
4 ohm dvc or 2?
Here is 2 4 ohm DVC to 4 ohm load:
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-22-2011, 11:05 PM   #3
Cbrown67
It says in the book that came with the sub that 2 or 4 ohm
Old 01-25-2011, 01:28 PM   #4
tubbedII
needs more $$$
tubbedII's Avatar
If you look at the speaker magnet, it might have the ohm rating on it. If the book says 2 or 4, then the speaker comes in 2 or 4 ohm ratings.
Here's a link that will help ya once you figure out the speaker rating: http://www.the12volt.com/caraudio/wo...igurations.asp. Just choose 2 speakers, then your ohms and click the button to see all the ways it's possible to be wired.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 02-07-2011, 08:24 AM   #5
msgross
msgross's Avatar
my DVC's had a small jumper from one VC to the other then the main + and - ran to that one... worked well...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-07-2011, 11:05 AM   #6
81ShrtBox
MadMan
81ShrtBox's Avatar
What ohm load are you trying to accomplish??? And what type of amplifier do you have??? Mono block, D class, 2 channel, and the lowest ohm rating on the amp??
Also, knowing what brand amplifier will help
81" Shortbed C10 Full Restoration underway, who needs a budget?? LS Pro Touring Build
81ShrtBox is offline   Reply With Quote
