Old 01-24-2011, 09:06 AM   #1
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
12 Bolt Truck Rearend Parts......
Bought from Summit Racing but never used: Fits 12 bolt Truck rearends.
Eaton part # ETN19556-010
Differential, Posi Performance, Limited Slip, 30-Spline, GM, 12-Bolt, 4 Series, Each
List: $470.00 SOLD
Richmond Gear part # 4902801
Gear, Ring and Pinion, 3.73:1 Ratio, GM, 12-Bolt Truck, 4 Series, Set
List: $180.00 $140.00 + Shipping
Ratech Install Kit part # 316K
Ring and Pinion Installation Kit, GM, 8.875 in., Truck, 12-Bolt, Kit
List: $85.00 SOLD
Moser Engineering A30-70GMT2 - Moser Engineering Replacement Alloy Axle Shafts
Axles, Rear, 1541H Alloy Steel, 30-Spline, Chevy, GMC, Pickup, Suburban, 8.875 in., 31.313 in. Length, Pair
I had 5x4.5 bolt pattern installed
List: $245.00 Sale for $200.00 + Shipping
Total package from Summit Racing would cost $980.00 + tax and shipping.
I will let it all go for $820.00 + shipping.
I'll accept personal checks and items will be delivered when check clears.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 01-24-2011, 09:57 AM   #2
Bishops Trucks
KEEP ON TRUCKIN'
Re: 12 Bolt Truck Rearend Parts......
Bump
JIM
Old 01-24-2011, 08:05 PM   #3
Bishops Trucks
KEEP ON TRUCKIN'
Ttt
JIM
Old 01-25-2011, 06:38 AM   #4
Bishops Trucks
KEEP ON TRUCKIN'
ttt
JIM
Old 01-26-2011, 04:42 AM   #5
Bishops Trucks
KEEP ON TRUCKIN'
Can't believe no one wants a posi unit for their pride and joy.
JIM
Old 01-28-2011, 08:22 AM   #6
Bishops Trucks
KEEP ON TRUCKIN'
ttt again
JIM
Old 01-31-2011, 07:57 PM   #7
hexafamily
Might be interested in the install kit if you separate, depending on shipping to 64086.
Don
'57 Chevy Nomad
'70 Buick GSX
'72 Cheyene (Boys' truck)
hexafamily is offline   Reply With Quote
Old 02-01-2011, 07:23 AM   #8
69rut
I have a '69 truck axle with six lug wheel I want to convert to 5 lug. Will your axles work? I am not sure of the spline count or lenght.
trailers are for boats
69rut is offline   Reply With Quote
Old 02-01-2011, 12:56 PM   #9
Bishops Trucks
KEEP ON TRUCKIN'
69rut, the spline count is 30 spline and are the same length as the stock axels with a c-clip. If you could slide one of your axels out and check to see if it's 30 spline also, then we could see if they would work.
Hexa, Shipping would be $15.00 in a flat rate box, so total would be $75.00 shipped.
JIM
Old 02-01-2011, 02:02 PM   #10
69rut
Thanks. I'm asking for my brother, so the final decision is with him, but put me down as first refusal. I will pull one of the axle shafts out and check the spline count and length. Can you tell me what the lenght of your axles are and from which points you are checking?
What is the 8.875 dimension for? And arer both axles the same length?
Old 02-01-2011, 02:15 PM   #11
69rut
Ok I called Moser and have the details I need on the length and etc. Your axles may be too long, but I want to be sure. I will post back soon.
Old 02-02-2011, 07:30 AM   #12
69rut
Thanks for the info etc, but these axles won't work for me.
Old 02-02-2011, 08:49 AM   #13
Bishops Trucks
KEEP ON TRUCKIN'
Ok rut, thanks for looking. I'm not sure what Moser said but these are for 30-Spline, Chevy, GMC, Pickup, Suburban, 8.875 in., 31.313 in. Length . Good luck with your search.
JIM
Old 02-03-2011, 09:26 AM   #14
hexafamily
Thanks for getting back to me, but I'm going to hold off for now.
Don
'57 Chevy Nomad
'70 Buick GSX
Old 02-04-2011, 12:55 PM   #15
Bishops Trucks
KEEP ON TRUCKIN'
your welcome and no problem Hexa.
JIM
Old 02-08-2011, 05:33 AM   #16
Bishops Trucks
KEEP ON TRUCKIN'
ttt
JIM
Old 03-10-2011, 05:43 AM   #17
Bishops Trucks
KEEP ON TRUCKIN'
ttt
JIM
Old 03-10-2011, 12:34 PM   #18
KrashMan454
KrashMan454's Avatar
I am interested in the gear set and install kit. I went to Pull A Part and found 5-Lug 3.73 under a 69 c/10 a couple of weeks ago. Pulled the cover and it was a posi. Only problem was the ring gear looked good but two of the teeth were broken on the pinion. everything else looked good and turned over and rotated ok. I will check the carrier this weekend to see if it is a 3-series or 4-series for sure. Will let you know by Monday. I just want in line, but if you get a sale don't let me hold you up. Krash!
KrashMan454 is offline   Reply With Quote
Old 03-10-2011, 05:12 PM   #19
Bishops Trucks
KEEP ON TRUCKIN'
Hey Krash, I'm in no rush to sale it so your first in line.
JIM
Old 03-15-2011, 09:13 AM   #20
KrashMan454
I am going to pass for now. My carrier has damage and I am going to explore some cheaper options. Thanks for holding it for me and good luck with the sale. Krash!
Old 03-15-2011, 04:12 PM   #21
Bishops Trucks
KEEP ON TRUCKIN'
No problem Krash. Good luck with your search.
JIM
Old 04-24-2011, 08:40 PM   #22
ffk
ffk's Avatar
is the posi still for sale?
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604)
ffk is offline   Reply With Quote
Old 04-24-2011, 11:32 PM   #23
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
can you tell if the bearing set has Timken bearings, I would not want bearings from china, thanks
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 04-25-2011, 03:08 AM   #24
james97cobra
I really need the eaton posi but you can buy it for 398.00 shipped from ebay. Can you do any better on your price? Thanks.
james97cobra is offline   Reply With Quote
Old 04-25-2011, 05:17 AM   #25
Bishops Trucks
KEEP ON TRUCKIN'
Yes it is ffk.
I'll have a look at the bearings and let you know Chevytrucklover.
Sorry James, I just can't give this stuff away. Prices are firm, if you can get it from ebay at a better price then that would be the way to go.
JIM
