Old 01-24-2011, 11:57 PM   #1
60ratrod
yes, i do
60ratrod's Avatar
throttle a little sticky
fortuneatly enough not while i'm driving. just when i'm at idle at a stop light or in traffic i have to put a little more force to get the peddal to unstick. so could it be bad throttle shaft bushings or just a gummed up throttle shaft? been thinking of porting the throttle body so this might just be the opportunity. but i would also replace the throttle body before attempting any kind of porting and polishing so that way if i make a fubar i won't be a$$ed out, just mildly inconvenienced.
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 01-25-2011, 08:07 AM   #2
orange70350
orange70350's Avatar
Re: throttle a little sticky
try checking for carbin build up on your intake blade i had the smae thing happen to mine
orange70350 is offline   Reply With Quote
Old 01-25-2011, 10:37 AM   #3
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
I think there was a TSB out for this problem a while back if you have cable throttle. spray some lube on both ends of the cable, that should fix it
'85 swb
droppedgmc is offline   Reply With Quote
Old 01-28-2011, 11:22 AM   #4
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
It's carbon buildup behind the throttle blade from the EGR. Pull the throttlebody off, clean it good, that should fix it right up.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
